ColdSteel Master Hunter 3v ( Taiwan )
Purchased for my 60th Birthday ( A while back ) . ( $230 ish Oz Bananas )
Anyways , wanted one for a very long time and finally had an excuse for shelling out large ( knife large - Deep end of the pool for me )
The edge was FUBAR to the naked eye ! I just had no idea how FUBAR it might be ?
I put the knife to the rope for a 50 slice fail with the factory edge . Since I slice in 50's , this is about as bad as it can be !
There could be a reason for the 50 slice fail ?
Looks like that seeing eye dog has found a new company to work for ! ( Seriously - the edge was shit )
I reground the edge with the white wheel ( 80 grit 250mm ) and it took about an hour to clean the edge 90 to 95% ..
The tip is still quite FUBAR .. TO clean it up 100% , a lot of material needs to be removed . ( See pictures - taken after much grinding - followed by more grinding )
Some tool lingered near the tip long enough to make hollows in the edge ..
Most factory knives FUBAR the tip or near the handle .. This 3v was FUBAR both ends to the extent of one hour on the grinder to clean most of the edge .
It blows chunks when the factory does not have some one who knows how to make a bevel / edge ..
The other FUBAR ... The thickness of the blade is not even ..
Right near where the blade starts to curve toward the tip , the blade swells .............. ( *&^&$#&^#@(*&$ ) F this N that !
Oh dear !
Anyways ! I reground the edge / bevel 80 grit ..
The factory angle was 15.5 degrees ( Against the flat of the edge ) .. Wow , that's rather tight for a factory edge ..
And the factory edge did not feel good on the rope .. ( FYI )
Now reground ! It felt fantastic ! I tried to regrind closer to 16 degrees ? ( Yeah , I tried )
But the knife felt good on the rope right till the edge rolled ( and still felt good ) .
I did a quick wood strop and the knife was slicing paper .. ( Edge roll )
Stropped back rather well as well ... ( 16 degrees ? )
I havent checked the video as yet , so ? How many slices on the regrind ?
50 Factory - So the regrind did what ?
