Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
It depends. That's probably an unsurprising reply, but it really does.
Getting the most out of a steel during heat treatment comes with a risk. If it's too finicky to get spot on, major manufacturers risk needing to bin whole batches that didn't turn out.
If it DOES turn out (which it should) and they manage to get a couple more points of hardness out of the steel, then manufacturers will need to deal with all of the chipping and breakage issues caused by people who shouldn't have nice things. Both scenarios increase cost.
Conversely, custom makers are arguably in a better position to push their heat treating a little further. If it goes wrong they're not thousands of dollars out of pocket and their customers are probably less likely to make a YouTube video of them throwing it into old car doors
Usually, quality brands do a pretty good job of getting a high performance result out of heat treating.
There are companies that really know how to get the most out of a steel during heat treatment (Buck's 420HC comes to mind, as does Opinel's 12C27M). There are so called custom makers who don't understand why you shouldn't treat 52100 like it's 1080. There are also custom makers who know exactly what they want from a steel and how to get it. Some are leading the way with heat treating steels they specialise in.
Edit: did I completely misinterpret the question? If so, my answer is...it depends![]()
"better results" is what makes this a hard question to answer.
Will (good) production companies get consistent ht with known results - yes.
Do they often play it safe and keep steel a little softer (oversimplifying, but trading toughness for edge retention) - yes.
Would I ask anything more of a production blade - no.
Can a (good) custom maker modify the ht protocol to optimize for certain characteristics - yes. As always, everything is a trade-off. They can prioritize edge retention over toughness etc. And this doesn't even start the discussion on how blade geometry impacts all these things as well...
I really appreciate the access we have on BF to the custom makers. HT is just one part of the equation, and meaning no disrespect, it is not necessarily something every custom maker focuses on. So a custom maker that "does his own" heat treat might be good, bad, or somewhere in between. Possibly no different from sending it out to Peter's - which offers known/reproducible quality control. If you are specifically interested in heat treat, there are some makers who really strive to get the most from the blades and they might be a good place to start your hunt.
Strider's HT is as good as it gets, which means it will be better than many custom makers.
will all custom maker always have an optimal heat treat over production knives? NO
So iv been pondering this since it came up in a thread I had about custom knives and production knives. In general would you say the company's that do ht get better results then the custom makers that do their own?
If they are both good they are both equal, but from my experience factory is much more consistently good. Buying a custom is really a gamble, unless you had a previous good experience with a specific custom maker. I would say any of the powder steels multiply that "custom gamble" by a lot...
Any old Al Mar, or even a Parker brother style cheapo, if made in a Seki city factory in Aus-6, Aus-8, or with 440 stamped on it, will be just outstanding... These can have edges that will be holding up even at 8-10 degrees per side while chopping wood, with no visible damage (especially Al Mars, but Parkers too)... Most factory made stuff, no matter what the price, including Randall, is very consistent and usually very good... Customs are really hit and miss, including some of the best names... "Custom" wise I trust Lile's 440 and D-2, Colin Cox 440, and Steve Voorhis 5160 at slightly more open angles (16-18 per side, instead of my preferred standard of 12 on factory stainless), and that's about it from what I got (I would place customs roughly at around 30% pass in my experience, while factory stainless is above 90%)...
A lot of the time a custom will look like it's doing fine at moderately thin angles, but then run a nail along the edge, and it shaves nail material where the factory is totally pristine from many times more the amount of work chopping wood... Curiously, this tendency to micro-fold doesn't go away even if you open the edge angle considerably, especially with the powder steels... Customs in plain non-powder 440 that fail tend to fail as spectacularly as plain 440 from Seki city is spectacularly good in a Parker Bros cheapo...
Gaston
Custom HT ... becomes a practice when you want maximum of steel which give the default geometry according to the task ... so variable.
Now if you follow ... here is a handful of examples of individuals who are eager and willing to push the limits of metallurgy believing in science ....
Photo Hardness not asked to express height ... but the attention it will devote particular custom blank and the other with the respect a piece of steel.
Regular bad english Joe :thumbup:
