Ausseknifeknut
BANNED
- Oct 26, 2013
Thinking of adding a compass to my survival gear and learning how to use it , what's a good starter compass? I don't mind paying for a really good one
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
If in Australia make sure you get one meant for the Southern Hemisphere. That said, Suunto A-10. You won't need a separate protractor. Just a map sheets with a declination diagram or know what the magnetic declination is.Thinking of adding a compass to my survival gear and learning how to use it , what's a good starter compass? I don't mind paying for a really good one
Yes if you are fully trained and practicedNow memorize EMGA
E Easterly declination: to convert a M magnetic azimuth to a G grid azimuth, A add the declination.
3. So if EMGA,
then EGMS (S=subtract),
and WMGS,
and WGMA.
Just remember EMGA and you can sort out the rest from it.
It may last a life time. Depends on what the needle is made of and how it is magnetized. Once it is off, if it ever becomes off, the compass needs to be replaced.A compass like this will cost about $50 US and will last a life time
How do you take accurate bearings with a baseplate compass
And if you can remember when the wind is blowing in a full storm and you are cold and wet and slightly hypodermic, or overheated from a sandstorm Yes if you are fully trained and practiced
So all you really need is a base plate
But it is so much easier with a sighting mirror and a pre-calculated magnetic declination
i like one with a sighting mirror because it can double as a signaling device and as a mirror - as in checking for debris in my eyes or putting my contacts on in the morning (i can do it without but it's slower).
if you want one of the best ($60'sh) then checkout a suunto mc-2g. adjustable declination so set it once and don't need to constantly recalculate and global needle so it works anywhere.
by the way, here's a nice land nav article from esee: http://jungletraining.com/map-compass.pdf.
You are going to have to hunt a bit. couple of problems that you face, most of the no-name brand compasses at places like BCF are crap, but they over-charge for the Silva ones. That being said, you only get warranty though the retailer. If you can track down one of the Brunton TruArc line without spending an arm and a leg shipping it, go for it. Otherwise buy a silva in store from someone. Online a lot of the retailers are risky as in, they don't know which ones to send, or if its one of the many drop-shipper stores, you might end up with a north american one. I don't remember where I got mine, probably spent my birthday money at BCF, because I needed one. Features are cool, but here you will be spending well over double US retail for one of good ones.
When I moved I thought I'd just easily find one here, no trouble. Turns out that since only three people here actually walk anywhere most of the time, compasses are not that easy to find, unless you are looking for a dash mount one!
