I carry a Sig P290 in a Black Point mini wing holster. Carries well and has been extremely reliable and I shoot it well.
Carry guns come down to what you and your body can conceal well, what fits in your hands, and your current clothes. Some guns, yes, you may start buying a pant size larger to accommodate a larger pistol. A good holster and belt makes a world of difference too
If you're leaning towards a 26, a 19 is a pretty viable option too. A friend a couple years ago got a 26 and by the time he added the finger extension and the +2 capacity floor plates, it was a 19 with a short barrel. He later got a 19 and shoots it a lot better and is happier with it. That's an individual case though, I don't have a problem with my pinky not being on the grip but some do
Edit to add: ditch the Remington idea
That's just him probably being a glock person. I don't clean my guns unless there's an issue or I shoot old corrosive ammo. And they keep working.
If you're using it as a range gun, lead works fine, I know a lot of people that shoot lead in their glocks and it shoots it really well. If you want to shoot a FMJ or copper plated bullet in it though after you shoot lead, most people I know clean the bores out really well. Probably depends on the particular gun in general though, even mass produced, each barrel is unique in its own way.
The above is true, with an exception.
Decided a few days ago I was done posting in threads about guns, to many opinions, but this subject is something I have a bit of experience and first hand knowledge of.
The lead issue isn't something that's been or can be fixed and its not just with Glocks, its an issue with all pistols with Glock type rifling. It just happened to be more of an issue with Glock because of the way the chambers are made, and most of the issues I saw, and heard of were with the .40.
Doesn't seem to matter if its soft lead or hard, its just a matter of time and the front portion, (from chamber) about an inch or two, will get lead basically melted to the inside and fill the rifling. Firing a copper jacketed bullet through it will clean it out, sort of, but it can also cause to much pressure and the chamber being the way it is can fail.
From what I've seen, and heard, and shot, just use a few copper jacketed bullets every fifty rounds of lead or so seem to take care of the issue.
I used to shoot Ultra Max, ( Glock .40) back in 04 , 05, a lot, I mean 500 to a 1000 rounds a weekend at least once a month, sometimes twice a month. I never blew up a gun, but I did brake a few, noticed the lead coating the front of the barrel after about 100 rounds and shot it out. Glock came out and stated that you shouldn't use lead bullets, (Minus a jacket) in their pistols, haven't looked to see if that's still the case, but they had a bunch of failures back then so that was their policy to fix the issue.
I think If I remember correctly the failures were coming from continuous firing of lead and no cleaning and eventually the chamber and the front of the barrel would just give.
Basically the leading would cause the caliber of the barrel to be to tight for the projectile to go through, (Think 9mm hole and .40 bullet) without the barrel and unsupported (Not as supported as others) chamber to stay together, causing a failure.
So, JMO, if you are going to shoot lead bullets, pay attention, shouldn't be a problem, I know most of the people on here are lead slinging, gun fighting, big **** dragging operators that have BTDT and have the passport stamps and t-shirts to prove it.
Merry Christmas and Happy Hanukkah.
PS, I only quoted the above post because I agreed with it and just thought I needed to add something to it.
