Contact wheel discussion
REK Knives
Moderator
I need to order another 4" wheel.... my polyurethane wheel from USA knife maker went bad after about 5-6 years (got all gummy and can be removed with fingernail). Was just looking at Bader contact wheels but they offer two different types of 'rubber'... neoprene and urethane. If I get one from them, which material should I get?
Polyurethane of course , if you ask me .What hardness they are ?
I think I want to stay away from polyurethane... like I said it went bad after a few years. I wasn't sure if plain urethane is the same thing as polyurethane. I want to stick to good old rubber! You can select hardness you want. I was going to go for 70 probably.
If you think so ..........I see lot of industrial grinders around here . My friend have several big one .All of them have polyurethane wheels .On my 40 inch wheel I will use polyurethane and that was recommendation from experts I ask .
Bader wheel for sure. They originated the belt grinder.
Sorry I may not be making myself clear haha. Bader offers both (see here, scroll down a bit), I'm trying to figure out which material is best :)
Give bader a call and tell them what you are doing and they can recommend one
I called bader... They said that the urethane is the same as the polyurethane and that the neoprene is the regular rubber. But they don't make them with a 1/2" shaft so they would have to custom make it.
I know this doesn't really answer the question and I know this is an unscientific and tiny sampling size. But earlier this year I made some 1" contact wheels out of neoprene and urethane. The neoprene wheels wore out and needed dressed every couple days. So, when I made the urethane wheels I went ahead and made three because I didn't think they would last very long and I'm still on my first one after making about a thousand knives with it and it hasn't even needed dressed yet.
Polyurethane comes in a lot of different flavors. I had a really crappy wheel from KMG that fell apart pretty quickly and I suspect it was cast urethane, although I don't really know, however the extruded urethane I bought from MSC seems to be better stuff. Although it's not very old yet so who knows.
Sorry if this doesn't really answer the question, but I have been marveling at the wear resistance of this polyurethane.
Edit to add: I say extruded urethane, but it could have been cast I don't really know. It was a hollow tube. *shrug*
Also edit to add: these materials grind really well. I was able to machine them on my lathe with a tool post grinder and I could not believe how well it responds to grinding.
Also also edit to add: I was able to attach them to the hub with regular West systems epoxy and it has held up just fine.
That's good info, thanks for sharing Nathan. I guess I didn't consider the possibility that there are different grades of polyurethane... The stuff I have that's degraded badly is made by Sunray.
Edit: I called KMG and the lady on the phone didn't sound too sure about anything, but she did say they use Mid American Rubber. So I called there and am waiting on a callback to see if I can figure out specifics on what KMG is currently using to see if it would hold up for me.
This is my KMG contact wheel
If you look closely, you can see that it has started to deteriorate enough that it could affect function. Because of this I haven't bought more contact wheels from KMG.
I think that Northridge seems to have pretty good contact wheels. I bought a 10" from them that works well and hasn't transformed into a fragmentation device.
wow! Yeah I'd say that can infringe upon grinding just a hair lol
I wonder if they have always used the same wheel manufacturer or if they have switched... that's interesting! the 14" wheel I got from them in 2015 is still quite pliable and not gummy/disintegrating like my poly wheels from the same time period are. when was the above wheel purchased? Just curious!
yeah I would order Northridge but they only have 1 size of contact wheel unfortunately.
It's actually pretty difficult to find a good quality rubber contact wheel w/ a spacer in the middle these days... I'm probably gonna have to make a custom order through contact rubber corp. and make my own spacer.
Side note: my dad's neighbor bought that Mori CNC machine from you this past summer... small world :D
My KMGs are old. One is from the first week of manufacturing them. The original wheels are all fine. The 14" wheel I got when Rob started them is still fine, however long they've been available.
Time changes things, only sometimes for the better. I recently bought a work table for a disc grinder. It is, unfortunately, a good example of poor tolerances.
oh thanks for that! It looks like it would work w/ a 1/2" diameter bolt (which is standard here in the USA)... but it would have about .005" play on each side (13 mm bore is .511" inches)
They use M12 bolt which is 12mm ? half inch is 12.7 mm ? You can enlarge that hole to 12.7mm ?? What I m missing ? What is that 13mm bore ?
Here, this one says that it has a 13mm bore but uses an M12 bolt... it's strange, doesn't seem to match haha
I miss that .But it is absolutely no problem , i would say you are lucky .That .005" play on each side don t matter at all ..........Look here why https://bladeforums.com/threads/how-to-mount-contact-wheel-on-belt-grinder.1771840/
ahhh yeah that actually makes a lot of sense! I actually messaged that guy in Poland and he was very responsive... he said his brother is actually selling the parts in the USA so he sent me a link. Here's a better pic of the wheel so others can understand how it works
Contact Rubber Corporation will be able to help you out. Best in the business.
