The attention to fit , finish and minutia is superior to everything else I own . I appreciate that . I tend to be a nit picky bastard when it comes to my tools so . . . they impressed me.
As far as bearings in the pivot that is actually kind of a bad idea as far as a work knife the design is weaker and when grit gets into it . ..
Lets just say a pivot with washers is stronger twisting / prying wise (lets say you fell down a well and had to twist and pry to save your life . . . OK . . . OK ) .
When a knife is well made : surfaces truly parallel and flat and smooth the washer pivot is going to drop or pivot about as well as bearings . And I am a guillotine like dropper fan .
The blade on my 21 drops with a "hydraulic" like pace ever so slightly slower than one of my Spydercos that I have put VERY light lube in and left some play in the pivot these latter drop WHAMMO quick even though they are washers.
I left my 21 as it came from the factory . I know that if I put the light lube in it and backed off the pivot screw like a degree it would drop quick as well.
I just enjoy it as Chris Reeve intended and am HAPPY as it is .
The blade on mine came with pretty much the best edge / geometry / sharpness I have experienced on a stock from the factory knife .
My BBB 15V cuts very well and is very sharp but the Chris Reeve has a touch thinner blade behind the edge so it trims finger nails effortlessly ; one of my tests for my own edges that I put on .
Here is a
link to my old "review" of mine after I got it . Bare with my silliness at the start . . . there really is a 21 there eventually .
