- May 25, 2007
I was just reading an article about the use of copper in hospitals to reduce the spreading of resistant MRSA bacteria. The use of copper in say washing bassins, doorhandles will kill a lot of bacteria.
http://www.copper.org/antimicrobial/homepage.html
Would it be a smart idea to introduce pure copper disks or even better a copper mesh in say a water bottle? If you place it on the bottom, the copper will kill a lot of bacteria.
It seems it's highly effective against say E-Coli. After 90 minutes 99% of e-coli ( a common and dangerous germ in survival situations) is destroyed.
I know silver has a similar strong effect also as an antibacterial and antifungal. Just think if the use of silver threads in insoles against "smelly feet" and the use of silver in antimicrobiological cremes ( like flammazine to treat burn wounds, and kill fungi and both gram positive as gram negative bacteria)?
As copper is non toxic, and it will kill bacteria, it might serve as a good low cost germ killer, when you don't have access to boiling the water?
It seems our forefathers found out it's benefits too!
http://www.copper.org/antimicrobial/properties/history.html and http://www.copper.org/antimicrobial/properties/efficacy.html
Back to the copper drinking bottle? I know it will probably not kill parasites etc, but in a pure survival situation, parasites can be treated afterwards, while an E-coli attack could kill you in the bush. Or what about using this copper mesh in stainless or nyalgene bottles?
http://www.themanstoreonline.com/To...sh-Metal-Cloth-Fabric-p/todol copper mesh.htm
or http://www.microwireproducts.com/products/knittedcopper.shtml
and stuff some inside your water bottle?It wont take much space but it will have a huge contact area.
See this article from research in India. http://linkinghub.elsevier.com/retrieve/pii/S0035920309000182
"Abstract
Water inoculated with 500–1000 colony forming units/ml of Escherichia coli, Salmonella Typhi and Vibrio cholerae was stored overnight at room temperature in copper pots or in glass bottles containing a copper coil devised by us. The organisms were no longer recoverable when cultured on conventional media, by contrast with water stored in control glass bottles under similar conditions. The amount of copper leached into the water after overnight storage in a copper pot or a glass bottle with a copper device was less than 475 parts per billion, which is well within the safety limits prescribed by the WHO. The device is inexpensive, reusable, easy to maintain, durable, does not need energy to run and appears to be safe. It has the potential to be used as a household water purification method for removing enteric bacteria, especially in developing countries."
"Abstract
