Crushing H, please do explain more in depth
Ok … a mini discussion on Adhesion – for those who are interested….
There are more aspects to adhesion, and types of adhesive joints – but I will limit this post to those that are most likely to affect the tang/handle joint. Ever wondered how people make stuff stick to Teflon (a specifically non-stick substance)??? Hopefully by the end of this will you understand how.
I will try to cover the following issues that might affect your handle joint to the metal blade (remind me if I missed one :
· Surface cleanliness
· Residual organic chemicals in the handle material
· Surface flatness
· Surface roughness
· Glue bond thickness
· Mode of failure (tension, shear, peel)
So – there are two major contributing mechanisms that make an adhesive joint work: chemical interactions and mechanical interactions.
Chemical interactions are just that: chemical bonds between the glue and the surface(s) being bonded. If the glue forms these chemical bonds to each of the two surfaces, and is sufficiently strong in its body, then you have a successful joint. An example of this type of glue is cyanoacrylate (Krazy Glue). A great limitation on chemical bond based joints is the need for surface cleanliness – you want the glue to have direct intimate access to the active chemical sites on the material you are bonding to. Anything that gets in the way – especially organic chemicals of the oily or waxy type will do two things: 1) physically get in the way on the contact of glue to the surface, and 2) possibly compete for the active chemical sites of each, and reduce the number of chemical bonds between glue and surface (thus weakening the bond). Also, over time, these competing chemicals can compete with, and undo, successful bonds between glue and surface. Thus the practice of cleaning a surface with an organic chemical like denatured alcohol, isopropyl alcohol, or acetone – which “dissolves” surface organic oils/waxes and carries them away, leaving the bare surface to be bonded to.
There is, however, a “gotcha” on this: many plastic/resin based materials contain residual oils and other chemicals in the bulk of the material that are not bonded to the plastic or resin. Thus, even if you can successfully clean the surface of that stuff, and successfully create a bond using a chemical-bond based glue, these residual chemical in the bulk will (not can) over time migrate to the surface where the bond has been made. These chemicals compete with the chemical bonds between the surface and glue – and can “undo” those chemical bonds between glue and surface (technically this is a chemical active-site competition – which is the underlying principal behind all chemistry). So it is entirely possible that a joint will be made successfully, but then fall apart at a later time. Time is the enemy here – it might take a month or ten years …but that migration of chemicals in the bulk to the surface will occur.
Any material that has significant organic compounds can be subject to this migration effect of residual chemicals in the bulk material. These materials would include: fully synthetic (resin based) handles like Kirinite, manufactured materials like Dymondwood, resin stabilized wood of any type, and, I would believe, any highly resinous tropical wood (even if not stabilized). Also, purely chemical-interaction based bonds between disparate materials are just not that strong. Many materials, like Teflon, just do not like to make any chemical bonds to anything else. So, especially under the right circumstances (Mode of Failure – will cover later) purely chemical-bond based joints will easily fail.
All is not lost though: the other contributor to adhesion is mechanical interactions.
(I think I will stop this post here and pick this up at a later time – gotta get to the gym and get some exercise!!!
This also gives you some opportunity to let me know if I am just boring you with this so I can stop…..)
