Gossman Knives
Edged Toolmaker
- Apr 9, 2004
I hope this is clear enough to understand. I cord wrapped a PSK knife so if anyone ever needs to rewrap, this might help.
First, I use 58" of 550 cord. To start, run one end of the cord from the right side into the front hole. Bring the other end around to the left and put it through the same hole.
Next start wrapping until you get to the last two holes.
When you get to the end, run the cord through the top hole, under the loop on the right side and into the bottom hole pulling tight as you go. Bring it up under the loop on the left side.
Holding the end piece tight, use pliers to pull the front end tight. It will tighten the back end loop holding it in place.
When you're finished, cut the excess cord off close and melt it with a lighter.
Hope this makes sense.
Scott
Scott
