- Jul 3, 2019
Well I have a tourist en route to my house along with the small screwdriver add-on. I couldn’t leave well enough alone...
I will bite the bullet and try it with a 91mm SAK.I've pulled corks with a 91mm SAK, not fun perhaps but certainly doable even for someone with disabled hands like me if you know the technique. I'd really not want to do it with my 84mm Waiter though.
I'll try it thanks!The trick to removing a cork easily is to push down slightly first, this gets the cork “unstuck” then pull and it comes right out. Also by pushing first, it compresses the small air space, thus adding a slight pushback and making removal easier.
Whenever this question is asked corkscrew almost always wins.
Because it’s better.
I actually like the backside awl and use it quite a bit. I'm not a fan of the awl on the alox models, too wide for creating precise holes and I'd far prefer a small blade in its place in any case. I do indeed twin a Rambler (keychain) with my corkscrew 91mm for precisely the reason you mention. It's a lot of screwdriver capability.I think it is because the Corkscrew is a proper tool and the Phillips lacks in location and reach. I think all the tools on my Climber are good and multifuntional tools whereas the Phillips is kind of a one trick pony. I know some people don't like the backside awl but I love it as a scraper and it does a good job as an awl you just have to be careful for it not to fold on you. Also I think it is easier to add a Rambler to a SAK with a Corkscrew and you get two good Phillips drivers with the Rambler that can get recessed screws from #2 to #0. It is a lot easier to add a Phillips then a Corkscrew to your EDC.
The real trick is to use leverage like with a traditional waiter's corkscrew.The trick to removing a cork easily is to push down slightly first, this gets the cork “unstuck” then pull and it comes right out. Also by pushing first, it compresses the small air space, thus adding a slight pushback and making removal easier.
Those scales are really cool.I can't decide.View attachment 1537799
