I am bringing up the subject of an old thread (https://www.bladeforums.com/threads/fake-okapi-knives.1562929/) again because it was over a year old and I'm not sure what the rules about necro threads are. Better safe than sorry.
Anyway, I just got myself a new Okapi Big Sable and a Genet. The Genet was a replacement for one that I bought from Baryonyx recently (his last Okapi in stock, apparently), and lost a few weeks later. I bought myself the two new ones from ebay, from two random sellers, just because. There are a few features of interest: the Genet is exactly like the first one I bought, except that it is marked "Carbon Steel" instead of "Made In South Africa". That made me a little worried at first, but they both came in identical cardboard "Okapi Carbon Steel" boxes as seen in the previous thread (although for all I know those are something that sellers get independently for re-selling Okapis, and it may be no indicator at all). The Sable is marked "Made In South Africa". Perhaps they come in both styles at various times.
But what was most curious is that when I came to reprofile the blades, the Sable is made of steel that seems noticeably softer than the Genet. It just melts off under a diamond sharpener. Does it seem strange that they'd use two different types of steel for two different models? Maybe the Sable is meant for a different kind of end-user, or they are compensating for the greater cost of the larger blade and handle by using cheaper steel? I made me a little worried that it was a knock-off. From what I read on the last thread, it APPEARS to be all legit; it has the newer type "Okapi" lettering, and it certainly doesn't have the dual-sided bevel and angled edges of the counterfeit shown on the last thread. Just seemed strange to me.
BTW someone mentioned that their Okapis came with loose blades in the old thread; my first one was fine, but the two I just got were both quite loose. I found that this is easily fixed by putting one end of the rivet on an anvil or stone and tapping the other end with a small hammer with light force. The rivet heads are soft enough they flattened right down and tightened the blade up nicely. Nice and snug now (obviously, be gentle and proceed with care or you'll end up with it so tight you can't open it easily).
And while I'm at it, the Genet, at least, appears to have a design flaw. It looks like the edge of the blade rests on the rivet holding the back spring when it is closed (it shows inside the bade channel). If you let it snap closed, it will dent the blade. I cut a short piece of rubber band and stuck it down inside over the metal rivet, which makes nice soft bed for the edge to lie on. I did the same for the Sable, because the edge rests on the wood, even if it doesn't seem to actually touch the metal rivet on that knife.
And if anyone cares, in my opinion, the Genet is a much more useful size and shape for a knife than the "classic" Sable. The Sable looks cool, but as a practical EDC knife the Genet is smaller, more efficient and has a more useful blade shape, in general. And that's not even counting the harder steel, if that is actually the way they are made from the factory. Haven't tried any others yet (I'd like one of those sheepsfoot ones next), but of the two I'd choose the Genet, if I meant to EDC it (not to say that there's anything WRONG with an EDC Big Sable, just not the better of the two, IMHO)
