- Jan 27, 2002
Guys,
I'm about to make a home made air filter with a squirrel cage blower. I'm thinking of some type of box made of wood? to surround it. I assume this blower I have just intakes air on the SIDE holes, as there is no other intake really. I was thinking of putting HVAC filters on either side of the blower, to filter the air as it comes in, and then put a filter on the output, for even more filtration. Is this what you guys have done?
I have an old belt drive unit, which will need a motor. I could use some suggestions on HP and RPM? It is a fairly big blower unit. The pulley on it for the belt, is about 6" - 8" in diameter. I was thinking a 1HP 1725 RPM motor would be good for it. What do you think? (I thought 3450rpm would be too fast, and might overheat the motor) Also, I'm not really wanting to spend top dollar on a motor. Probably pick up one off ebay or something locally.
Also, I have several electric compressor motors, (actually my buddy has them) and they all state the "rpm" rating clearly, but they all say "SPL" next to HP. How can I tell the HP rating???? In fact, every compressor motor I've seen says "SPL" next to the HP mark, and I don't know what this means.
Thanks for any other tips.
