Alright so S110V is a steel I recently gained experience with, so I will share my insight. It doesn't hold a razor edge terribly long, but far better than S30V. Getting the razor edge takes a lot of work, because the steel is incredibly difficult to sharpen. Basically you have to take your sharpening procedure and multiply the time on each step by like 5. The edge takes a near mirror polish on a surprisingly low grit (mine took it at 3 micron).
How you should sharpen it is based on your experience and tools. If you are comfortable with trying, and you have good stones (SiC or harder), you can take it to mirror with a lot of elbow grease. If you have good stones but aren't comfortable with sharpening it too much, you can leave it at a more coarse finish around 600 grit and it will cut well and for a very light time without even needing to touch it up. If you don't have good stones, and don't want to get any, I'd suggest outsourcing the sharpening.
