Cpm S35vn vs cpm154
Rsq
I have decided to make my first knife. I ordered most of the stuff i need, (files, sandpaper, sharpening system, etc, doing it the cheap way and seeing if it's worth pursuing farther). I have narrowed the steel i want to make it from to cpms 35vn and cpm 154. they are similarly priced, less costly than the damascus that i will replace the blade with for show, if this comes out well, but I cant get any definitive information that inclines me one way or the other. Everyone seems to love both. The traits i am looking for are: toughness, wear resistance, and finishability (able to take a mirror finish without orange peeling like d2' or remaining misty like the super high vanadium steels). I have researched them a bit, and they seem close in all respects. I dont want to buy both, so I was wondering if you guys could save me some money and weigh in. Which do you prefer and why?
I guess i can sum up the question in this way: two knives, all other things equal besides blade steel, which one would cut more cardboard and still be able to shave my beard, and not break if i loan it to an idiot who abuses it (so i can shave his dog of course)
Ah
Right
It will be a folder, blade length will be in the 4-5" range. I love tantos, so the first will likely be a modified tanto, but i want to make a wharncliff with the leftover material.
I'm tentatively going to throw m390 in the mix, as I have found it on aks.
If I'm overlooking something significantly better in this range, I want to spend under 30$ for at least 14 inches of 1.5x.125 bar stock. A little thicker is ok if thats all there is, i can file it down. With 14 inches, i figure i'm pretty safely going to be able to get 3 blades. I have already picked out the 3/32 440c 1.5x18 barstock from knifemaker.com for the handle material. I want to make a pretty friggin perfect knife, then go all out on the furniture, but first I want to make sure that the knife mechanism and fit is as baller as it can be. I have some great ideas (if I may say so) for experimental lock and deployment mechanisms, unlike anything I've encountered yet, so I want to see if I can execute them and if theyre as good in practice as in principle.
I will be using 440c for the handles, and i'm going to get everything ht'd at peters.
As a beginner knifemaker building a folder is hard , well above my skill level. A simple full tang hunter is always a good start but if your up for it go for it .
CPM154 will certainly give a high polish , don't know about S35VN.They're close but perhaps the S35VN will be a bit more wear resistant ,CPM154 a bit tougher .
440c for the handle ? Explain your choice for that.
Folder: im very technically minded, and and tinkering is a skill i've elevated to an art. If I make a few cardboard models first, im sure it wont take too many attempts to get it right.
440c for the handle: its stainless and durable. Ht'd to a slightly lower rc than it would be used in a blade for, it should provide exceptional anchoring for the blade. I want it to be simple and slim, without sacrificing ruggedness. I will have scales that will absorb shock better than the 440c can. Is there a reason not to use 440c? Its cheap enough and comes in the size i need it in. Why not?
Another reason for 440c is that i will have enough to practice grindimg a blade with b4 i use the more expensive steel, and not need to buy additional materials
Go with CPM-154. I would do the whole knife in it....handle and blade. Makes sense to me, anyway.
You sure have caught my attention !!! I always want to see "new" ideas in folders. Please show us some pictures. My best to you on your "make". Frank
Definitely use the CPM 154 , if your going to put the time and effort into it why use inferior steel like 440c . If you want to make a Work In Progress thread I'd be very interested in seeing the process start to finish.
CPM154.
I've been very impressed with it, and it may become the main stainless steel I use in the future.
S35VN is great too, but doesn't seem to finish as well.
So ive ordered 3 steels, cpm 154, 440c, and 1095. 1095 bc its cheap and this is my first project, so good practice. I want to make several of these with what ive ordered, hence the 440c. Save some money.
As soon as they arrive i'll start a WIP thread. I will update it often for advice/criticism
Can you expand a bit on your answer, please Ray? Why do you like it the most?
Because cpm 154 and s35vn are about the same as far as cost, work, and finishing. I can't tell them apart in performance just by using them. The difference IMO is that s35vn is a newer "hotter" steel. If you have two identical knives, one with 154 and the other with s35, the s35 will be more attractive to a potential buyer. That's just how I see it.
