Crc Silicone Sprays, Is It Safe??
SILICONE SPRAYS,IS IT SAFE ON LEAHTERS (WATERPROOFING)AND TO LUBRICATE FOLDERS?ALSO,CAN IT BE APPLIED TO BLADES FOR RUST PREVENTION?PLEASE GIVE ME U'R PROS AND CONS. THANKS, JUSTRIGHT:confused:
Silicone spray is used with fair success to waterproof finished (NOT suede) leather. It will serve as a fair corrosion inhibitor, and fair lubricant, but there are products which will serve much better for these last two purposes. Thin Film Corrosion Inhibitors such as Tuf-Cloth and Tuf-Glide, as well as products such as Mil-Spec and Renaissance Wax will provide better corrosion inhibition.
PTFE/grease and PTFE/oil combinations as well as MoS2 products will provide better lubrication. Check the search button for vigorous debates on these topics.
I find silicone spray most useful as a neoprene '0' ring lube.
Hope this helps, Walt
Hey JR...
I use Snap silicone spray quite abit around the shop...
For sheaths I use it mainlly on blades with Kraton or similar handles.. I use it when a blade is having an extremely tough time going in and out of a sheath...
The difference is like night and day,,and can actually make an otherwise tight knife pop/slide right out of the sheath if you aren't careful...
Do not spray silicone directly into a sheath as once the liqud evaporates it will leave a sticky residue on the inside of the sheath,,which will attract debris...
Rather spray it on your finger and slightly wipe the inside of the "Mouth" of the sheath with a little bit of silicone...Does a nice job at this...
Sometimes I will use it on folders,,but find it can also make them sticky,,until it's worked in...
ttyle
Eric...
