Theres a thing about blacksmithing that its basically slave labor that doesnt pay out the time put into it.
That said A2 is a steel most people do not have the patience the time or the arm capable of forging A2 out into a blade, you get about 5-8 seconds per heat to swing your hammer before you enter an unstable austonite phase and the metal will crack, and it has twice if not more the toughness of 1095 to forge. Its not like most simple steels where you can go from orange to red, you go from medium orange to dull orange and youre done.
While its just a simple steel and theres nothing remarkable about the blade itself; Criswell hand forged his blades just with a hammer and used a steel most smiths are too weak to forge.
Criswell was a badass.
A2 doesnt really take a hamon or flex with a coat to get the bend. That curve on the spine is done by forging, doesnt take much a light bevel and youre done rest can be stock removed pretty easy, I did a tanto of a2 two weeks ago and its pretty much the same thing.
The way you can tell is the organic curve, a2 is pretty pricy too so cut away doesnt make sense for the metal.
So what you're telling everyone is that A2 doesn't take much forging to make a spine curve, "a light bevel and you're done," but most smiths are too weak to forge it. That A2 is too pricey to do just stock removal so curvature should be forged, but forging is slave labor that doesn't pay for itself.
Have you ever seen a Criswell sword that wasn't in a photo? They don't have dents in the spine like that billet you posted above, that looks like it was hit with an angle grinder. I'm just wondering why you're posting all this iffy and convoluted stuff about forging and swords all over the forum. There are people here who want the info posted here to be accurate or at least attributed.
Lol. Theres machines for curving steel, and presses with bends in them, it doesnt make sense to to get overstock make a trace and then cut off 60% of a material, no you just bend a bar and it has the same bend going throughout the bar, or you just make a few taps.
Again mecha youre a noob.
