Hey guys,
I recently bought a CRKT Ignitor, and while very happy with the overall fit and finish of the blade, (I'll probably do an extensive review after more...extensive use of it.) I'm having a little trouble with the sharpening. Now, I'm not overly skilled in the sharpening area, all I'm really using are an old whetstone and a honing steel. Not really in the position to invest in another sharpening system as of yet, so freehanding will stay for the moment. I've been doing fine on one of my other blades, cheap knockoff of an Ontario XM-2, which appears to have a hollow-flat grind. I'm not sure if I'm using the right terms here, frankly a lot of the sharpening talk has me confused a lot of the time, so I figure I'll throw out a line to ask for help.
From what I understand, a knife can have two grinds, one in the blade and another on the edge. If I'm right (and not a complete ass) the XM-2 knockoff is hollow ground in the blade and the edge is flat ground, simply continuing. The CRKT Ignitor however, seems to be hollow-sabre ground. While not a big issue, I've noticed that the cutting edge seems a little thick? It isn't separating material as well as I'd like.
I suppose my question is, with my current set up, would it be possible to bring the sabre ground edge closer to a flat grind? And what would be the best way to do this.
Apologies if you have no idea what the hell I'm talking about, sharpening/blade grinds are still a little confusing to me, despite the myriad of threads, articles and diagrams I've scrolled through. I'm a slow learner that way.
Any help would be appreciated!
Thanks guys.
Thanks guys.
