Cutlery rivets
Anyone use these much?
I had some handle material another maker wanted and I sent it to him as a surprise. He sent me a box of "stuff" that I got last night and one of the items was a bag of cutlery rivets (100 male and female)... I've never used them and neither has he... Looks to me like the handle had better be about finished before installing, am I right?
Any insight for those of you that have?
Charlie
Oh, he also sent me some SWEET mystery wood as well! :D
Countersink and epoxy the compression rivets flush with the semi-finished scales. Sand bearing in mind that you only have ~1/32" of rivet head thickness to play with. NOTE: If epoxy gets in the female part you will not be able to "compress" the rivets.
Thats what you see on most simple kitchen knives.They work well.You really dont need adhesive.That also is what the pivot pin is on a Case (and other) sodbusters.
I've used cutlery rivets on several Russell Green River kits. I cut the scales and drill the holes with the same precision that is required for pins. You can use a step bit made for rivets or drill a hole for the body of the rivet then use a Brad bit for the head. I epoxy the scales and the knife then place and set the rivets by tapping with a hammer with a small anvil as support. I set my rivets below the scales by using a punch and the head of a nail set below to countersink both sides of the rivet. I still clamp the scales while the epoxy sets. I then finish the handle flush with the tops of the rivets.
I get he handle to about 90 percent, not much removal left just get the scratches out, I drill the rivits with a bit that does the hole and countersink in one step. I always epoxy, makes a good sealant and a secondary hold on the handle. I do not clamp, I like the rivit to provide the clamping pressure. I use a press to push the rivit together, not too tight.
