While working today I damaged a special vacuum connector for a saw I use to cut masonry. After work I examined the damage. The part is a thin tube molded from glass-reinforced plastic, probably FRN, which angles into a plate that directs the dust to the port. I cracked the thin tube in two places near the open end while setting the saw on its side carelessly.
My first thought was the rough it up and use some glass cloth and epoxy to effect a repair. Then I remembered that I had purchased some 6" Kevlar reinforcing fabric to use as an abrasion guard on a postponed sign project. Yeah! Let's use Kevlar!
So I get the roll of Kevlar cloth and go to cut off a 6" strip, from which to cut a narrow strip with one factory woven edge to avoid sharp points at the open end of my tube. Grab scissors, cut fabric, easy - right? Wrong. Scissors won't cut the stuff, it just forces the blades apart and slides between them. After several tries I move to some Fiskars multipurpose shears that cut paper, cloth, and sheet metal. Same problem.
How about a knife and a straightedge? Utility knife with bimetal blade and steel ruler on workbench, heavy pressure, cuts partway through. Raggedy. Heavier pressure and I am through, but at the cost of a 1/8" deep scar in the bench.
Now I do the second cut and figure what I need is extreme slicing action to part the fibers. So I place the square of cloth on a paint stir stick to save my bench and slice with my shaving sharp Rat 1 folder, using the belly of the blade to slice back and forth with increasing pressure, guided by the steel ruler to the side of the blade. I split the paint stick in half without getting through the Kevlar. So I go back to the utility knife right on the bench and get 'er done at the cost of another wound in the bench top.
The repair went well and will be stronger than new when fully cured. I think I need a pair of Kevlar shears. I think the edges on those are zirconia ceramic.
Anybody here have experience cutting this stuff? What works for you?
Bill
Bill
