IMHO odd shaped holes require a more advanced approach than those described above, not to denigrate using a needle file to achieve that hole cheap. Needle files can achieve the desired result albeit with blistered hands a likelihood to say nothing of serious cussing.
You need an EDM or a Waterjet
Electrical discharge machining
From Wikipedia, the free encyclopedia
Electrical discharge machining (
EDM), also known as
spark machining,
spark eroding,
burning,
die sinking,
wire burning or
wire erosion, is a manufacturing process whereby a desired shape is obtained by using electrical discharges (sparks).
[1] Material is removed from the work piece by a series of rapidly recurring current discharges between two
electrodes, separated by a
dielectric liquid and subject to an electric
voltage. One of the electrodes is called the tool-electrode, or simply the "tool" or "electrode," while the other is called the workpiece-electrode, or "work piece." The process depends upon the tool and work piece not making actual contact.
As an alternative but equally (I believe) accurate you could use a waterjet.
Water jet cutter
A diagram of a water jet cutter. #1: high-pressure water inlet. #2: jewel (ruby or diamond). #3: abrasive (garnet). #4: mixing tube. #5: guard. #6: cutting water jet. #7: cut material
A
water jet cutter, also known as a
water jet or
waterjet, is an industrial tool capable of cutting a wide variety of materials using a very high-pressure jet of
water, or a mixture of water and an
abrasive substance. The term
abrasive jet refers specifically to the use of a mixture of water and abrasive to cut hard materials such as metal or
granite, while the terms
pure waterjet and
water-only cutting refer to waterjet cutting without the use of added abrasives, often used for softer materials such as wood or rubber.
[1]
Waterjet cutting is often used during fabrication of machine parts. It is the preferred method when the materials being cut are sensitive to the high temperatures generated by other methods. Waterjet cutting is used in various industries, including
mining and
aerospace, for cutting, shaping, and
reaming.
Just my 2¢ of course.................. or perhaps my $20,000 (because, as my wife often remarks, I have too much money).
Corey "synthesist" Gimbel
