I've used an 18 or more tpi bi metal blade on my 14" bandsaw for years. Manage to get between 2 and 3 years use out of each blade cutting the same thickness ti. No lube, no babying of any kind really other than keeping the guide close, making sure the small pieces you cut off are not blocking the path by getting stuck in the center plate and also my only serious recommendation would be if you use the saw for cutting wood be sure all the dry saw dust is out of the thing before sawing titanium of anykind with it or you're likely to start it burning.
Ti sparks to high heavens and it can sting if those fly on bare skin too so cover up your face, your hands and wear protection. If you use a vacuum make sure its free of flamables before proceeding also. It may not ignite but it can sure smoke. Been there done that on both issues for fires in the bottom of the saw, and smoke in the wet dry vac. Contrary to how a lot of guys cut the thinner titanium I cut it fast speed with the saw just like I cut aluminum fast. Seems to zip through better to me that way and grab less. Slow on the thinner sheets really wasn't comfortable. Stan Fujisaka told me that once and sure enough he was right. He uses a 14 tpi blade by the way. I always cut those two metals fast now and only slow it down for thick stock steel. I cut my titanium for all my folders up to .160 thickness and for the thousands of .040 and .050 low rider and standard style pocket clips I've made since starting them with a regular wood cutting Delta/Rockwell bandsaw. (same saw Stan uses actually) Oh yeah, you may want to create you some kind of a push stick also. It helps a lot.
STR
