- Jun 11, 2006
As some of you might remember I annealed a small trial batch of D2 planer blades. I have started my testing of this material the other day and wanted to share my findings as I went along. Plus my mind is full of questions as to how I should go about logically testing this stuff. And by testing I don't mean make a knife and see how it cuts. I mean how to go about settling on optimum heat treating temps as well as cryo times and temper temps and time. As I start adding it all up in my head it seams like an allmost limitless set of possibilities. How does one lay out a proper game plan on how to atack such a mountain of work/data.
I'm getting to a point in my life/knife making where "good" is not enough. If I'm going to spend the time I want the best I can get and that includes ringing out every last drop of performance out of my steel. Because of this I have said good bye to 5160. It has been my go to steel for a very long time but it's just not providing me with the performance I'm after. Most of the blades I do are hunting/skinning knives with a dash of fillet knives mixed in. Because of this I have chosen D2 as a steel worth the effort going after and investing the time/money into doing it right.
So with all that being said any advise you can provide would be most helpful. I'm hoping Nathan will pop in and set me stright. But here is what I got so far.
The blades where annealed from 1850° to room temp at a rate of 40°/hr. After that I cut 2 identical chunks except I pre quench one at 1750° in oil and then both where plate quenched from 1850°. I then clamped in the vise and beat them till the snapped off. I then inspected the grain on both and to my eye the grain size was the same. I don't know how fine a grain D2 can get but I was impressed with the results. I was dreading that my annealing would have messed up the grain as I had read that re doing the heat treat on D2 can be problematic. This is why I was hoping my annealing would clean the slate so to speak. The grain was so fine you could not see the grains with the nacked eye. I then got out my 30x magnifier and inspected the grain and it looks to me rather good.
Here is a picture of the grain at 30x magnification.
I measured the hardness after grinding away all the decarb and I'm sitting right at 87shore (63rc). I then did a test temper at 950° as I don't have my dewar yet and after the temper it still measured 62-63rc.
I'm not planning on using 950° temper I was just wanting to see how it would affect this D2. I feel the more data I can collect the better off I will be.
So that's it for now. I hope the dewar arrives soon so I can really get after this. But in the mean time I will use this time to plan out a proper "plan of atack" so any advise would be great.
Thanks guys
Thanks guys
