CPM D2 would be excellent candidate for applications that need a screaming sharp edge (at least compared to ingot D2). D2 has chromium carbides, which standard aluminum oxide stones struggle in abrading. Hence, D2 is known to take a not-so-sharp of an edge, and hold it a long time. That is because the sharpening stones most have are of aluminum oxide variety, so the martensite matrix gets abraded, but the large Cr carbides not so much. Hence the adage, and it's true. However, with diamond stones, or even silicon carbide, those carbides can be abraded, and the result is a much sharper edge. For slicing cuts, tho, that's why ingot D2 excels....large carbides to act as "teeth", much like a saw.
CPM D2 has much, much smaller Cr carbides, and while the aluminum oxide stones can't really abrade them, they are quite small (in comparison), so the edge feels more refined when sharpened on natural stones, aluminum oxide, and the like.
If you have diamond plates (and especially diamond or CBN emulsions) you can sharpen any steel to a screaming sharp edge (provided you have good technique too...sort of a given).
