For those of you who recommend a well tamped, sealed canister I have a short story. A close friend and I had welded up a matched set of 3 inch wide canisters; they were made up of wire cable and 4600 e powder. Both cans were tig welded closed. By chance or a stroke of good luck one had a small hole in the weld around the lid. The other was a perfect weld with no weep hole. We didn't know there was a difference in the cans. We heated the vented canister first and welded it when it came to temperature. The second can was coming to temp as we were working the other can down. When it exploded inside the forge we both hit the ground. It blew one whole side off the three inch canister. It sounded like someone had pulled the trigger on a twelve gauge inside the forge.
I make up all my canisters with a weep hole these days. The explosion cured me of sealing them completely.
Do yourself a favor and leave a weephole its dangerous to do otherwise, Fred
