Danish oil vs boiled linseed oil. Pros, cons.
FWIW from a WOOD Magazine article that compares six types of finishes:
https://www.woodmagazine.com/materials-guide/finishes/choosing-best-wood-finish
Drying oils,
- " including boiled linseed oil and pure tung oil, penetrate the wood surface and react with oxygen to cure."
- "Easy to apply"
- "Easily damaged, easily repaired: Drying oil cures too soft and thin to protect against moisture vapor or abrasion. It also darkens with time as it continues to oxidize."
- "Try it on carvings and objects you'll handle infrequently"
- "But avoid it for any project that requires moisture or abrasion resistance, especially outdoor projects. Oil provides almost no surface protection and does little to block moisture vapor, making it a poor choice for most furnishings you'll use every day."
Oil/varnish mixes,
- "such as Danish oil, enhance grain while laying down a thin film. "
- "Goes on with a cloth: Comparable to drying oils for ease of application, these mixtures also penetrate the wood. The difference? They leave an extremely thin, soft surface film. "
- "Minimal protection, but easy to fix: Adding varnish to these mixtures doesn't significantly increase a project's abrasion, moisture, or heat resistance compared with boiled linseed oil."
- "Try it on indoor projects where you'll want a soft, satin sheen, or a simple, rustic finish as on a simulated antique."
- "But avoid it for surfaces you'd rather protect against wear and abrasion instead of constantly repairing the finish, as on dining tables or chairs."
Based on the WOOD Magazine article, I guess I should not prefer either. The most protective finish they discuss is
Polyurethane varnish
- "Tricky to apply, but difficult to damage: Nothing short of chemical strippers or aggressive sanding will remove polyurethane, but that also helps it survive wear, moisture, and chemical damage in the first place."
However (maybe I'm a Luddite), I have only used two types for handles. I have used Watco Walnut Danish Oil for the darker look, but mostly my first preference is BLO.
Bob
