- Dec 19, 2012
Quick review of my current day hiking setup.
I've been using the Hill People Gear Highlander with the HPG Shoulder Harness. I went with the Highlander over the Tarahumara as I'm a big guy and the stuff I want to stick in there is bigger than the average. I'm using Kifaru Pullouts to organize gear in the Highlander. These work especially well for the FAK and PSK which I strap to daisy chains.
All loaded up and ready to go. The Shoulder Harness is very comfortable. Not seen in these pics is the Nalgene bottle that I carry in the bungie cords on the shoulder harness for quick access. The Highlander fits everything I take on the typical day hike with room to spare. The compression straps make it so I can suck it down as tight as needed depending on the load, keeping the weight close to the back. If rain is in the forecast (when isn't it in the Colorado Mountains?) I throw the rain jacket in paracord loop at the bottom of the pack for quick access.
Opened up and some of the loose stuff removed so you can see the Pullouts. Larger Pullouts float in the bottom while the FAK (red) and PSK (blue) are strapped to the daisy chains to keep them at top with easy access. The FAK and PSK can easily be pulled out and slipped into pants pockets for when I don't need the complete pack.
Pullouts in use here are two Small for the FAK and PSK, Medium for misc stuff, Large for Cooking/Fire kit:
Some in use shots:
I really like this setup as it gives me a lot of versatility in packing the Highlander and for future expansion. For longer backpacking trips, my plan is to get the HPG External Frame when it comes out (or just get the Ute for now while I wait) and use the Highlander as a compression panel. Then, I can unload the main pack in camp and use the Highlander for day hiking away from camp. Much better solution then my old way of carrying a small daypack inside the main pack and transferring a lot of gear back and forth.
In my opinion, you can't go wrong with Hill People Gear. Evan and Scot have some great designs and are good guys in general.
Some in use shots:
