- Nov 29, 2000
I brought this up on another thread but was told I needed more info so here's pix and, what is on the motor id plate:
20180918_080942 by rynegold, on Flickr
20180918_081115 by rynegold, on Flickr
The id plate is corroded and hard to read but it says, line for line:
D. = T56H 1057 M-WM
Y(?)TPR = F756HC(Z?)
HP=1.5 1725 RP(M?)
ARM VOLTS=180
" AMP = 7.3
FORM FACTOR= 1.3
INSUL CLASS = F
MAX RA(????) = 40
IML-RA?? =CONT.
MS R? TE?
What I want is to use this for a drive on a new grinder. What are the chances? And will it run at a higher RPM than 1725 or will drive wheel size take care of that?
Found this:
https://www.axcontrol.com/automation/reliance-electric/dc1-drives/DC1-70U
And this... I'm guessing this is the "KBAC" yaw'll were talking about?
These would work yes? The Reliance one is $329 and shipping. Still though is 1725 enough RPM for a grinder motor? I can't even remember what my Bader motor is right now.
D. = T56H 1057 M-WM
HP=1.5 1725 RP(M?)
ARM VOLTS=180
" AMP = 7.3
FORM FACTOR= 1.3
INSUL CLASS = F
MAX RA(????) = 40
IML-RA?? =CONT.
MS R? TE?
Found this:
