DC Variable speed drill press that can Mill
I was Looking at the Nova voyager dvr drill press and I saw that they are working on a metal version called the vulcan.
https://www.teknatool.com/product/vulcan/
It can run off of 110 or 220
From the Manufacturer:
The NOVA Vulcan is an exciting new class of machine that has all of the versatile features of a metal drilling machine but with additional capabilities of a milling machine, in one cost effective hybrid package. The NOVA Vulcan is designed to handle all of the normal metal working tasks but also has the ability to mill parts, as required. Note: additional accessory compound table is required. This is a major step up from conventional drill presses that can handle heavy drilling but not milling. Or a milling machine that can handle milling but not heavy duty drilling.
Designed specifically for metal working, with a stable and strong 3MT Spindle, and ER32 Collet System for maximum holding flexibility. The vibration free operation delivers smooth accuracy and the coolant feed delivers better finish and longer tool life. The metal working table provides slots for clamping and metal working accessories and a trough for coolant.
The NOVA DVR range of machines are the only intelligent machines on the market using Adaptive Control™ Software. With its 1.75HP/2HP high torque motor, exceptional structural strength and smart design, the NOVA Vulcan has the power and capacity to handle a wide variety of projects with ease. NOVA Vulcan DVR delivers incredible smoothness. With no belts to cause vibration, a computer that automatically adjusts performance and solid cast iron construction, the Vulcan is one smooth & quiet operator. This delivers the ability to drill faster and more efficiently. Plug n’ Play Easy to use, push button electronic variable speed with forward and reverse. Smart computer controlled motor only draws as much power as it needs for the project being worked on. The DVR motor can save up to 50% energy and emissions over conventional motors.
I thought this may be very useful for those not looking to spend thousands on separate mill and drill press. Not sure when they plan on getting it to market.
i know what kind of MINI mill o coudl bbuild and still save $ vs that. why are there no pictures of the base and X Y table (i see table size as 13x13) but no listing of travel. i sure woudl not be buying one till i got much more info. have had a mini mill for over 12 years now broke the plastic gears and swapped to belt drive. good little drill press that has no problem making light milling cuts (gets more use then the bridgeport in the shop)
I'm always dubious of VFD controlled drill presses. They lose too much torque at the lower speeds, where you most need the torque.
Trying to mill on a column type drill will generally not provide good results. The cutter will catch and pull the table sideways. There is a reason that true VM's have a bed and ways. It's all about the rigidity.
Now, this thing might be great at drilling holes but anything larger than a 1/4" mill on an X-Y cut would probably cause issues.
Hmmm Note: additional accessory compound table required. Rigidity and precision milling just flew out he window!
For the $1850 listed there are MUCH better options in a milling machine. Check Grizzly and other places.
Seems like a rather poor solution to a problem that's already been solved with a knee mill.
I didn't look up specs, but I imagine the travels would be less than or MAYBE equal to a mini mill. So you're basically just getting a mini-mill that can drill slightly bigger holes? I don't really get it.
Now, the $1850 price tag... does that include the xy table? Shipping for either? Probably not. You're still going to need a vise even after buying the table. I'd take the money all of that would ultimately cost, and buy a used knee mill with some tooling.
