Demon-repelling sword
Mecha
Titanium Bladesmith
Hello all,
Here is a demon-repelling sword, for driving away evil.
It was described as a "sumo tanto" by the sword mounter (I can't do woodwork like that).
This is one of the very first welded-edge multi-alloy forged titanium blade billets I made, so it was a bit of a test piece. The body of the sword is 6al4vELI body implant alloy, welded to a BT23 Russian armor alloy, with 15-3-3-3 aerospace alloy filler. It's hard to see the layers, but the HAZ is visible and didn't seem to go way with grinding. The closest analogy to a Japanese sword lamination is wariha tetsu, basically a bit edge.
It's a tall, flat hira zukuri grind, just over 20" to the habaki, and around 1.5" wide. All accents are polished buffalo horn, other than the copper.
Thanks for looking.
looks great, Sam! Killer piece all around
This is really gorgeous. I've been reading about the special geometry on swords like Lancelot Chan's supreme cutter and Motohara. Did you find a "sweet spot" as far as edge geometry goes to best work with titanium alloy and being able to handle cutting tough targets like trees and bamboo?
That is one amazing blade. I would love to own one like it if you ever make another. Superb craftsmanship and lucky owner.
Thanks!
A sweet spot depends on what the blade is going to be used for, and the alloy too to a degree. In general they work best when thin, with a very acute bevel grind. These types can generally handle cuts of hard green bamboo, even mis-cuts, very well. The metal has a high shock-force and impact toughness.
