I enjoy freehand sharpening and even developed my own technique which i call 204-freehanding. In the past 2yrs i successfully freehanded hundreds(!) of various edges (EDC knives, kitchen knives/machines/cutlery, gardening tools, other cutting tools, etc.) to scary sharpness and in all modesty
i'd call myself an experienced sharpening dude not a beginner anymore! But it wasn't until recently that i really learned about the 100.0% detection and 100.0% removal of the burr. This was so mind-blowing (because i was thinking that i knew it all) that it's worth sharing.
During the sharpening process, how do we check for sharpness, for progress?
Imho the most efficient way is to try to light up the apex 'from above' with a directed light source. For example you could wear a headlamp (Olight H1 Nova), hold the knife vertically with the apex facing your chest, then slowly rotate the blade away from your chest. The apex will eventually face your eyes and you would see light reflections bouncing off the dull spots/sections of the apex line. The sharper the knife, using any diffuse light source like daylight won't cut it, you will need a small powerful flashlight for this 'flashlight trick'.
The 'flashlight trick' can tell you within a second which 1mm spot still needs some work.
But here comes the first lesson. A light-reflecting spot (or section) of/on the apex can mean two(!) cases: The spot is either still dull/blunt/rounded or damaged or alike, or you're seeing the light reflections from a macro burr formed at that spot! Either way you're not done yet but keep working accordingly until the entire apex stops reflecting any light 'from above'. And that's then the point where i used to call it quits, rightly so because the edge would cut tomato skin and phonebook paper beautifully. So where's the problem?
You wouldn't expect or believe it, but most likely there is still a micro burr at/on the apex!
So do check with your thumb after all, on either blade side, and be honest to yourself! And if you can or cannot feel it, we come to the second lesson: the 'flashlight trick' is not complete until you check the edge 'from behind' on either blade side. Hold the knife horizontally parallel near your chest, with the spine facing your body. Then slowly rotate the knife axially, turning the blade downwards. At some point your headlamp's light would hit the edge at a perfect angle 'from behind' such that the micro burr reflects light into your eyes. Wow, what a revelation, just crazy!
Now we are ready to formally distinguish and define macro burr vs micro burr.
Btw this OP is not about deburring techniques, but my personal repertoire includes dedicated freaky deburring strokes on a portable ruby, very light edge-leading strokes on ceramic, very slow edge-leading strokes on ruby (possibly at higher angle), edge-trailing strokes by a loaded narrow wood strop, and much patience. In principle there is no difference in technique for removing macro burr or micro burr. And some practitioners don't even distinguish between the order of magnitude of burr size; to them macro burr is burr, micro burr is burr, same same ha ha, and burr must be 100.00% removed. They are the A+ masters in the sharpening community and always end up with hair-whittling edges.
- macro burr is so big that it produces visible light reflections (in direction of the light source), if directed light hits the apex vertically 'from above'. macro burr ("macro wire edge") can be easily felt with your thumb and it can be reduced and eventually broken off through alternating balancing strokes. If you see broken off "wire" on your stone, that's macro burr. As soon as the apex stops reflecting light in the aforesaid manner, congrats you broke off all macro burr and your knife edge is scary sharp. And you could call it quits here. Note: Depending on the steel, macro burr cannot be reduced and/or removed through a loaded leather strop; it's not the way to go.
- micro burr is by orders of magnitude smaller than macro burr; so small that it produces invisible light reflections (in direction of the light source), if directed light hits the apex vertically 'from above'. Fortunately, micro burr ("micro wire edge") can be easily felt with your thumb, too. And with a focused/powerful light source directed 'from behind' at a proper angle it can be made visible, luckily (and who would've known?). I posted a helpful photo on Page 2! The ambitious perfectionist will look for it and try his best to remove it. Note: Typically micro burr is extremely persistent and is even raised by balancing strokes on Spyderco UF wtf. It can be very challenging and time-consuming to try to "pluck the micro burr off the apex" while not raising fresh micro burr.
