Good morning BF! I have gotten very comfortable with my edge pro and can achieve great results on most blades. I now have two knives waiting for some attention but I do not know which route I should go. I bought the apex 4 and have since added the CKTG brand of diamond plates in 140 and 400 grit, as well as the 6000 polishing tape. I made some balsa strops and have diamont paste for them. So far I have had great success with this setup but I am looking to add a few more diamond plates or stones because I have an M390 and Elmax knife that both could use a new edge. My dillema is which ones to buy. I am assuming that the old addage "you get what you pay for" is true here. I wanted to get something in the 800, 1200 grit or somewhere in that ballpark. I have seen great reviews regarding the Atoma diamond plates that they sell on CKTG, but those things are VERY expensive! I have seen on gritomatic many different options but with limited review. Anyone have experience with the ones from gritomatic that can let me know how they perform? Should I just suck it up and get the shapton glass stones or will those not perform well on these stubborn steels?
TLDR: Have edge pro, which diamond stones are worth spending money on?
Hi,
it depends on how much money,
but I would argue most any diamond plate is worth it
as long as you're aware of and dont mind the potential issues
for ~$4 you can get 1mm diamond plates in any "grit" from 80 to 3000
Size: Approx. 17 * 7.5cm / 6.69 * 2.95in
you can also get them in 1mm x 9inch x 3.14inch for $7.99
they even come in squares like 7x7 and what not
4mm thick $16.99 150*50*4MM CG416 Weight: 250g Diamond Grit: 400# 600# 1000#
mounted on plastic 10inch $21.84/$22.99 400#/1200# 250x70x10mm LX1602
8inch 8mm thick metal 28.35/31.50 203*70*8mm. LX1012T #400/#1000
1.2mm thick 10inch $19.99/$17.99 1PC Single side Professional Diamond Knife Sharpener Sharpening stone Whetstone 1200 Grits 250x70x1.2mm DMD1610
ok the above listed ones aren't the same pattern as atoma,
but some are full plate, some are honeycom, some have dots
the problems with these they could
take a month before they arrive using free shipping
could need returning back to seller because
come damaged or falling apart,
could be easily damaged despite using the required low pressure with them,
need straightening/flattening (the thin stuff)
need gluing to a backing/board to stiffen up
come too coarse and need breaking in or
zero pressure super ultra light lapping to give finer grit finish
lots of people buy this stuff from ebay/aliexpress/amazon...
not a lot of people review this stuff by comparing to more expensive stuff
but it all has value just depends on what is most important
Compare this thing I can get locally for ~$20 versus a same size (6x2) red dmt fine 600 grit for ~$31 locally
What you see is tungsten carbide scissor sharpener, tunsten carbide knife v-sharpener, and ceramic knife v-sharpener, and 400 and 1000 diamond paddle
this paddle is cheaper online and DMT is same price plus shipping
how important is the supposed grit consistency
and whatever other benefits of DMT products have
at 600 grit? 1500 grit?
