Soo I ended up getting some chipping and I went with a secondary bevel with my kme 17° . So I'm wondering what , if any issues , will a secondary bevel cause . Is there a specific use for the second bevel ? I've never seen them on a factory mass knife so I'm guessing they are not particularly needed . Any input would be appreciated thx
So technically the edge-bevel IS the "secondary bevel", commonly cut at 15-20 dps relative to the centerline of the apex. The first or "primary bevel" is the one behind it that covers the face of the knife and gives it the primary wedge shape, commonly 5-10 dps.
Now, a LOT of knives also have a "microbevel" cut right up to the very apex of the knife. This is often applied in the process of burr removal after sharpening the edge bevel, and is usually 2-3 degrees less acute than the edge bevel itself. It may be applied with a flat stone or rod or accomplished via
stropping which gives the apex a micro-convexity that similarly increases the angle. You may not see that microbevel on your factory knife, but it is commonly there, even on knives as humble as an opinel.
The entire reason for a microbevel (which you might consider tertiary) or even a secondary "edge bevel" for that matter is to increase the thickness of the geometry directly behind the apex so as to support it for greater durability in use. Durability of a knife edge is dependent first upon the structural integrity of the edge material (the steel matrix in this case, with its inherent strength and toughness) and then the thickness of that material. Whether or not a tertiary bevel is "needed" is entirely dependent upon how the user employs the knife. When a user experiences chipping or rolling at the apex of their cutting tool, the first thing to try is application of a tertiary or microbevel at the apex :thumbup: You might try stropping to make your apex convex if you have the means available, otherwise go right ahead and resharpen at that new angle with your flat hone.
In summary:
1) actually a lot of factory knives have another bevel within the edge bevel, a 'microbevel' to support the apex and improve durability.
2) whether or not a bevel at 17-dps is required is dependent on your use. If you experience chipping at 15-dps then YES you need a somewhat thicker angle :thumbup: Someone else who uses their knife differently might not need it *shrug* It's your knife, your use is what counts.
3) Thanks for this update! Keep it coming, and enjoy that knife!
