- Nov 24, 1999
Alright, I know there's a few guys here into tractors. I've been workin on an old massey at work lately. Spent about 4 hours tuning it up this week after a few idiots gave it a once over and it went from running badly, to hardly running. They claim it was "running like a sewing machine" when they were done, but all the same I had my work cut out for me
I got curios about exactly what I was dealing with and if there was anything I could do to make things a little better. So I got to looking around at some stuff online and now I'm really puzzled.
The tractor appears to be a Massey Ferguson 135, several people are in agreement on this. The puzzler is that it has a 3 cylinder engine that runs on gasoline. I've been told (yelled at even) that its a perkins engine.
Well from what I saw on www.tractordata.com ....massey never built a tractor with a 3 cylinder gas engine. All the 3 cylinders were perkins motors and they were diesels . All the gas engines were made by contintental(also a couple chrysler)and were 4 cylinders.
So I'm wondering what the hell I'm even working on now, and whether a guy could even get distributor points or anything for it if he wanted to (this tractor has 5000 hours on it, and needs a little TLC!)
The fact that it doesn't appear to be a factory configuration becomes even more suspect when you look at some parts on the motor. The air cleaner and carburator are hooked together with a length of (2" or so diameter) rubber hose, held on with strap type pipe clamps (like you use with plastic push together pipe fittings) The fuel line coming from the tank to the carburator is peiced together..... metal line from tank, and metal line from carburator, hooked together with a hunk of rubber hose, and more clamps. Intake manifold and all appear to be a perfrect match though. And knowing the way things have been done around this place, it really wouldn't surprise me if some ******* cobbled something together.
So I guess my main questions are, did massey ever use a 3 cylinder gas engine? and if so, was it made by perkins?
Anyone have any idea whats going on here?
