Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The way I've always thought about it was sheepsfoot blades have a spine that is parallel to the cutting edge most of the length of the blade. The spine on a wharncliffe blade curves continually from the handle to the tip.
wharncliffe has pointy tip.I searched, but couldn't find a ready answer for this question.
In looking at the two blades, they appear very similar to me. What is the difference between the two?
Thanks!
I have a sheeps foot on the way. Next up is a wharncliffe.
Not sure I can see the difference between a Wharncliffe and an Ettrick - other than perhaps the beveling along the spine. I don't think I know enough yet to see the subtle differences.
There are also examples in-between. GEC calls this a Wharncliffe, but I call it a Sheepcliffe.
Pointier than a sheepfoot, but parallel spine and not quite as pointy as a Wharncliffe.
Wharncliffe was also a knife patttern before it was applied to a blade shape.Ettrick is the pattern, not a blade type. You can have different blade shapes on an Ettrick frame, but generally they use wharncliffes. The Ettrick is a long slender swayback frame with a handle to blade ratio of about two to one.
However, I'd be delighted if Jack Black or Charlie would correct me if I'm wrong of course
Paul
