Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
are you sure? I've never heard of the hardness described as strength.Strength and toughness in knife steel are inversely related to each other. Hardness HRc is usually used to measure strength and the Charpy impact test is usually used to measure the toughness.
When reading about the elements in different kinds of steel, toughness and strength are often mentioned. What is the difference between them?![]()
any ways, within the realm of "toughness" there can actually be several different properties. I read a really good little article on it, linked from here on bf, recently. things like lateral strength, edge stability, impact resistance, etc... "toughness" is usually referred to encompassing all of these traits, but some steels can really vary at which traits they excel at. I will leave the specifics for those more knowledgeable than I.
For me edge stability is more important in a mid sized folder than all out toughness like a chopper needs. for instance most people will tell you 1095 is tougher than your average stainless, or even "super steel". This may or may not be true, I do not beat on my knives in ways to break them, so far they have all been strong enough for me. However I have noticed with cpm m4, the edge is MUCH less likely to deform in any way compared to other steels I have used, including 1095. accidentally striking metal, ceramic, marble, stones, etc... this steel remains mostly unaffected when lesser steels would roll the edge or worse, chip.
It seems that tensile strength and hardness correlate with each other.
Tougness comes into play even if you don't hit it, if you just push on the blade hard. And a blade that has higher toughness would be less likely to chip or break.toughness is how hard you have to hit it before it chips or cracks
