What does it mean to dress the blade?you may need to dress the blade
The same as "dressing" your sharpening stones when they get glazed. The best way is to use a spinning Alox bench grinder wheel running around 300-500 rpm held at a 45 degree angle to the spinning diamond blade. This is the way they are shaped and dressed at the factory and the way I dressed all of my sintered diamond tools to like new cutting performance. Pushing an abrasive stick into the blade or cutting a cinder block or sandstone I have found to be totally useless. The best hack method is to use an angle grinder with one of those tough wheels used to grind welds and such.What does it mean to dress the blade?
Since I have cut around 20" of 3/8"-1/2" steel plate and bar with my diamond saw, I really need to get a band saw, I will say it's not that big a deal, but it is hell on your blade so don't expect to cut tile or stone with it when you are done.
To give you idea about my tools arsenals I have a hammer, plyers and a screwdriver LOL.what tools are at your disposal?
I was thinking to get a big bath made of glass or plastic, place part if the machete in the salty water, connect to a 12V power source and leave it for a week (I am not in rush). I think that a week later I will get a clean straight line of all the extra material "eaten" by electrolysis. Do you think is should work?Removing metal through chemical erosion is slow, really slow.
This is exactly the one. I tried to cut it with a heck saw and it does make a scratch but does not cut.Is it the one with the saw back that's shown on their website as a clearance item? If so you could just take a file to it and file the teeth down. If cutting it via other methods you'd still need to end up filing the cut smooth.
Can t be simple/cheaper then this to cut hardened steel.........And don t even try to cut steel with diamond wet tile saw , that would not work !. Is there any alternative technique to cut hardened steel?
Blades on picture are from T3 HSS steel , very rare and hard to find steel .@ Natlek
Is it a multi tool? What kind of blades those are?
