I have an old Kershaw Blackout. Old enough that the blade says, "Patent Pending". I think I got it in 1999. Torsion bar is shot. Got the 2 Torx screws out easily enough. But the last screw is brass (I think?) and it threads into a brass sleeve.The problem is that the sleeve rotates every time I try to remove the screw. Sleeve has 2 small notches. Tried inserting a small screwdriver into the notches but there's not enough bite and it still rotates. I think I need a spanner with 2 small pins or something that I can insert into both notches at the same time. Anyone have a tool or technique they've used? Attached pic is the sleeve showing the notches. Thanks.
20190602_084232 by Chris Thayer, on Flickr
