I think I posted in a bevel grinding thread you'd posted earlier about grinding bevels and keeping the grind line straight.
Unless there is a reason not to have distal taper in a blade, then it is a must. First off it makes grinding the bevels easier because you're not fighting that blade thickness forward if it's removed by grinding the distal taper early on.
All blades benefit from distal taper unless they are built to split materials, such as a splitting maul or machete. A blade that is made to stab benefits from distal taper because it is thinner forward. A blade that is meant to slice will function better with distal taper because the bevels are thinner forwards on the blade.
The cutting ability of a blade is dictated by what is behind the edge; how thick is the blade behind the edge? If a blade is ground with distal taper, then it is thinner as you go from edge to spine. A blade with distal taper will have more edge options because it is thinner behind the edge.
Bottom line is; if there is not a good reason to not grind distal taper into a blade, then grind distal taper into the blade. You'll be making a better knife.
Regards, Fred
