- Oct 2, 2014
Knife blades and seawater are usually something I do my best to keep apart, but when diving a knife must survive some of the most hostile conditions and its performance can be a matter of life and death.
This Mega Test Review brings together twelve knives from five leading knife brands and puts them to the test in real world conditions covering geometry, corrosion resistance, ergonomics and wet cutting performance, as well as comparing steel to titanium, serrations to plain edges, fixed blades to folders and dedicated line cutters to standard knife blades.
The selection of knives was specifically put together to show as many different aspects as possible and considerations which could be applied to knives not in this review.
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
Here we go!
The contenders:
First up, the contenders one by one. Due to the sheer size of the Mega Review and the testing, I've had to create are additional supporting reviews, knife brand by knife brand, concentrating on some more specific details of each knife. These are now all completed and can be found through the following links:
Benchmade 122S H2O - REVIEW ONLINE
Spyderco Assist Salt - REVIEW ONLINE
Promate Barracuda Blunt, KF593 Ti, KF090 Seal Folder Ti, KF505 Blunt, KF001 Line Cutter - REVIEW ONLINE
Whitby DK9, DK11, DK511/14 - REVIEW ONLINE
Cressi Giant Knife, Alligator - REVIEW ONLINE
These are the ones that arrived before a diving trip to the Ionian Sea.
The last minute entries which unfortunately didn't get to travel as much.
The following photos are of each knife tested.
Benchmade 122S H2O
Correction: in the data tables later in the review the 112S is incorrectly named the 112B.
The H2O fixed was originally developed for an elite military program. The knife features a blunt tip, opposing bevel for torsional strength and an integrated cutting hook.
Blade Steel: N680 (57-59 HRC)
Not specifically a dive knife, the Assist Salt combines the multi-functional versatility of the Assist model with the rustproof qualities of H-1 steel. The defining feature of the Assist Salt is its H-1 steel blade and lock bar. This material uses nitrogen instead of carbon to create a steel that is tough and completely immune to corrosion.
Made for the professional diver, the Barracuda has a Titanium blade and Titanium hammer on handle bottom. There are quick-release adjustable straps, and though the knife is easy to disassemble it requires little or no maintenance.
Promate KF593 Ti
Designed by scuba diver's for scuba divers, the light weight Titanium blade with easy-grip rubber molded handle requires little or no maintenance. The full tang protrudes through the handle providing a narrow Titanium hammer on the handle bottom.
Promate KF090 Seal Folder Ti
Light weight Titanium bladed folder requiring little or no maintenance with an adjustable lanyard for easy carrying.
Promate KF505 Blunt
Using a 420 stainless steel blade there is a hammer on the handle bottom and easy-grip rubber handle. The KF505 is easy to disassemble for cleaning and maintenance.
Promate KF001 Line Cutter
Heavy-duty line cutter with easy hold handle. Disassembles to replace the blade and includes 2 replacement blades (standard utility knife blades).
Whitby DK9
2.75 Stainless steel double-edged serrated/plain blade and Stainless steel handle.
Whitby DK11
The Whitby Divers Knife DK11 features a double-edged blade with one edge being serrated and the other is a fine edge. In addition to its multi-purpose blade, the Whitby Divers Knife DK11 features a hammer hilt, situated within the rubber handle.
Whitby DK511/14
This Diver's Knife has a 6.25-inch stainless blade and an overall length of 11 inches. The handle of the Whitby Diver's Knife DK511/14 is contoured moulded black plastic and the knife is supplied with a plastic sheath with arm/leg straps. A big, traditional, diving knife design.
Cressi Giant Knife
This knife has large dimensions that make it particularly effective during use. Perfect as a work tool or for particularly intensive use. Featuring a Japanese 420 Stainless Steel blade with black coating treatment for corrosion resistance.
Cressi Alligator
The CRESSI Alligator is a unique tool offering the function of a Knife and Scissors. The 420-Stainless Steel Blade has a Straight and Serrated Edge plus a cutting hook and shears. It comes with a Hose Mount Sheath.
The Blade and Handle Geometry:
Most knife specifications have a basic description of the blade geometry, but in this section I will be taking a more detailed look at geometry and balance.
Using a set of gauges and precision measuring equipment including a Vernier protractor, callipers, fixed radius gauges and the unique Arc Master adjustable radius gauge (the one that looks like a crossbow).
Key aspects such as the primary bevel angle, grind type, blade depth, blade thickness, length, weight are detailed, along with balance information.
The 'Balance relative to the front of the handle' tells you if the knife will feel front heavy, or if the weight is in your hand (a positive value means the weight is forward of the front of the handle). The 'Balance relative to the centre of the handle' indicates how close to a 'neutral balance' the knife has in the hand.
In the case of full convex grinds the approximate centre of the grind is used for the primary bevel angle estimate.
These measurements have been tabulated and are presented in smaller bite size chunks and also in one overall table.
Important - there are critical performance indicators here, in particular the edge angle of the plain edges, serrated edges and cutting hook edges. A larger angle reduces the cutting ability significantly.
The first four knives.
Please note the Benchmade 112S is incorrectly named the 112B in the tables.
The next four.
And the final four.
For a direct comparison these results are presented in a single large table. To see this comparison table, please go to the Exclusive Content at Tactical Reviews , but remember to return to this forum to discuss the review.
Corrosion tests:
In this Mega Test Review you get an insight into the full process I carry out for all my reviews, but in particular here we have very specific stages. You have already seen some of the studio photography, and technical testing (the parameters), and now we move onto a critical part of the performance testing preparation.
I have chosen to run the corrosion testing before any measured cutting tests, for the specific reason that you will not normally take a dive knife out of the box and immediately 'need' to cut ropes and line with it. It is far more likely you will carry it on a few dives before you really need it to cut anything or free yourself from an entanglement. So the idea here is to look at the cutting performance AFTER the corrosion tests, as if the cutting edge is actually damaged by corrosion, it may well fail you when you really need it.
As it turns out, the initial testing site in the Ionian sea, is one of the saltiest seas in the world with a PSU measurement of 38. This is where we digress into the subject of salinity, but I'll just mention a few key points in the preparation of the corrosion testing.
The chart below (from World Ocean Atlas 2005 data) shows how the salinity of the sea varies across the globe.
The units are shown in PSU which stands for Practical Salinity Unit. The PSU is derived from the ppt (parts per thousand) value of the salts dissolved in a kilogram of water. On average, seawater in the world's oceans has a salinity of about 3.5% (35 g/L, 35 ppt, or 599 mM). This means that every kilogram (roughly one litre by volume) of seawater has approximately 35 grams (1.2 oz) of dissolved salts (predominantly sodium chloride NaCl). Average density at the surface is 1.025 kg/l. Seawater is denser than both fresh water and pure water (density 1.0 kg/l at 4 °C (39 °F)) because the dissolved salts increase the mass by a larger proportion than the volume.
And breath....
So, due to not receiving all the test candidates before the trip, I needed to replicate the conditions of the initial corrosion tests to keep everything consistent. What I needed was seawater with the same salinity as the starting conditions (also to then be used for the wet cutting tests). This is not as simple as taking tap water and adding salt to it, as the chlorine in the water affects corrosion, and the salts in seawater are not just NaCl. So as a starting point I went to collect some local seawater (from the English channel). This typically has a salinity of 35 PSU, but I was collecting from a beach where rainwater runoff would likely be diluting the salinity.
