- Feb 4, 1999
I know cobalt and carbide bits can drill through harder materials than HSS, but does that mean they'll last longer, too? I finally started using cobalt bits instead of HSS yesterday and was pleased to get two whole 1/8" holes from one bit! And I made a 1/4" hole without burning that bit, either! But, I've had nothing but terrible luck with drilling and even after two 1/8" holes the bit started it's squealing routine, so I'd be surprised to get another hole out of it. At $1.25 per hole or so that's kind of expensive.
Here's what I do for 1/8" 1084: run my drill press at slowest speed. Center punch hole, clamp work to drill table. I use a cutting fluid that works for drilling and tapping on most metals. Use "chip" method... light pressure, get a couple chips on the metal, turn the press off, wipe the chips away, wipe the bit, do it all over again. Someone suggested that my 1084 may have a hard center, which isn't uncommon with that steel, but I'm wondering if I invested in a carbide 1/8" and 1/4" bit, would they last a lot longer than burning out bits every 1-3 holes? I've used this method on 1084 and burned out 2-3 bits on a single hole before. Confused....
