Every once in a while, or if there is grit in the works. Maintenance usually consists of a blast of WD 40, wipe-down and a drop of machine oil at the pivots. I have no regular schedule on this, but over years have experienced smooth operation and no corrosion on any of my several multitools (Leathermen and Vics.)
So Leatherman recommends oiling your multi-tool. Does anyone do this?
Sounds like it needs a good cleaning. If it's a Vic, soak in in hot water and detergent for a while, then scrub it, dry, & oil.You MUST oil your multitool, i made the mistake of not oiling mine and i found opening and closing the pliars became harder and they got sticky. i have tried to use oil to make them open and close properly but i cant.
that's why i dry-lube...
