Hello everyone, I searched this question but couldn't find it posted.
I was watching a video about gluing wood on Mathias Wendell's YouTube channel the other day. He performed very thorough tests on joint strength at different clamping forces. His surprising results were that loosely clamped, loose fitting joints were far stronger than tight fitting, tightly clamped joints. So I did a little more digging and found this article about epoxy http://www.woodweb.com/knowledge_base/Epoxy_Adhesives_Tips_and_Techniques.html
It states the same about epoxy. Many manufacturers recommend a minimum thickness of epoxy thickness to maximize strength. We all know clamping too hard squeezes out to much epoxy and compromises the joint. So hence the question, does anyone epoxy without clamping? I'm wondering if anyone has tested scale to tang bond at different clamping forces or if they can point me in the right direction to someone who has. I've seen videos testing surface prep but not clamping force. I wonder if greater joint strength can be achieved by not clamping at all.
Just thought I would check before I spent the time and money to test it myself. Thanks
