Does chromium negatively affect apex formation?
DeadboxHero
I sharpen alot of knives freehand on stones, belts , etc
From experience,
I've observed non-stainless high carbon knives form very nice edges quickly and de burr better the high carbon (greater then 0.8%) stainless knives.
I have a few idea about why but I honestly don't know.
I know the chromium has an affinity for carbon.
I also know that grain size and hardness are a factor
And that Chromium carbides are larger and softer then some of the other alloying carbides.
My thrist for knowledge has become a consuming obsession.
My question is (all other variables being equal)
How does the chromium affect the micro structure and why is it more difficult to form an apex and deburr.
For example CPM 10v versus CPM S90v
Thanks guys, I've been learning a ton about steel from all of your responses.
Shawn
I am way to unqualified to answer this, though I believe chromium will increase a steels wear resistance. Might have something to do with it.
I am interested in this as well. I'm no expert but it may have to do with carbide tear out. Large carbides may not be supported well by the steel matrix in a fine apex.
Diamond stones for sharpening may cut and shape those carbides and produce a finer edge whereas other sharpening mediums may erode the steel matrix more and leave the carbides unsupported.
Again, I'm far from an expert but it seems to me that that edge may still be more fragile if it is very fine.
I'm essentially convinced that bolded point above plays more into how well or how cleanly-finished any edge will be, more than anything else. If appropriate abrasives for the steel and it's carbides are used, and with use of good technique (99% of this comes down to proper use of pressure), I'm increasingly convinced the steel makeup usually doesn't matter too much in the end; with the added qualifier that the heat treat is good for the steel as well.
I used to be frustrated with 'gummy' low(ish) carbon, high-chromium stainless steels, like 420HC and many similar stainless steels used in inexpensive knives. Seems like burring was always a problem, and it was difficult to clean those up and still leave the apex crisp & sharp. I've since figured out most of those issues are mitigated by good use of very, very light pressure, combined with using abrasives that can cleanly cut the steel. This is a big reason I've liked using diamond hones, even on 'simple' steels like these, because diamond will literally cut ANYTHING cleanly, and at a featherlight touch as well; it's a perfect combination. My 420HC and Victorinox blades, both with chromium relatively high in proportion to their relatively low carbon content, are finished to my favorite edges using diamond hones, leaving edges that usually need no stropping at all and will pop hairs from my forearm at Coarse, Fine & finer grits. And the same touch I learned on those blades has transferred with full effect to all other steels I've sharpened as well, from VG-10, ATS-34 (both with tenaciously tough burring issues) and D2 (HUGE hard chromium carbides) up to S30V and S90V.
David
I say no. You merely need to use a stone that can cut those steels. Some of those chromium carbides can be large like those on D2. So, grit fineness and grit type work in this cutting. One doesn't need diamond to cut these. Many grits will do it, ceramic, chromium oxide, crystalline, to name a few. Burr removal is a different issue from the original post topic. Still, if you're working up a burr you're cutting/apex-ing the edge. DM
From experience,
Shawn
Chromium affects the microstructure in a lot of ways. The most pertinent to knives is it makes carbide formation easier, it makes hardening easier, and it makes removing retained austenite more difficult.
Chromium does have an affinity for carbon, and if enough is present, it will form carbides in preference to iron carbides. 52100 is known for containing more carbides than say 1095. These are mostly not really chromium carbides. They are iron carbides with some chromium dissolved into them. (Fe,Cr)3C for instance is cementite with some chromium dissolved into it. As the Cr, C, or both, goes up, the tendency is to form more and more unique carbides to chromium, Cr7C3 and Cr23C6. Another thing about the carbide formation is the usual composition of the eutectoid point (0.8ish %C) goes down. This means that steels like 420HC are actually hypereutectoid, though they contain only about 0.4%-0.6% carbon, but considerable chromium. Chromium carbides are not inherently larger than other carbides, unless one solely considers the molecular size carbides with only 4 to 30 individual atoms. Carbide size is controlled mostly by processing, whether it be use of the CPM process or similar, or by heat treatment of regular ingot steels.
Cr makes hardening much easier, reducing the speed required in quenching to achieve full hardness, thus moving something like 1095 from a water quench to an oil quench when considering 52100, or even plate quenching in 440 series, 12C27, etc. Were I making a chopping knife and could choose from 1055 or 5160, the hardenability difference alone would play a very large role in my choice.
The presence of large amounts of chromium reduces the temperature when the conversion to hardened steel is complete, which means that, if additional steps aren't taken, the amount of retained austenite will be considerable. There aren't many gummier structures to try to sharpen than austenite. Try putting an edge on 304 or 316 stainless to see what I mean.
IMHO, the difficulty often observed in sharpening the less expensive stainless steels is indirectly related to chromium. These difficulties arise from the stabilization of Retained Austenite (RA), the greater difficulty in getting rid of it, and the generally less expensive and involved heat treating procedures. The larger primary carbides may not be properly dissolved, RA may be stabilized and the amount may be excessive.
A word about grain size. The grain size of stainless steels CAN generally be larger than plain carbon or low alloy steels due to the higher temperatures needed in hardening. However, these stainless steels are generally more resistant to grain growth, so grain size depends almost entirely on processing.
I would say definitely not. Chromium helps the hardness and wear resistance. And, together with high amounts of carbon forms a very hard and tough edge.
I think it's just harder to grind the edge to the apex witch is the problem your probably facing. I have some knives that I wouldn't even try to sharpen on regular stones, simply because I don't have all freaking day. This is where diamonds come in handy.
In an attempt to answer your question, As I understand it anyway, it affects the structure by ,in many cases, forming chromium carbides, which are extremely hard and wear resistant. This makes grinding it more difficult, and burr removal an exercise in patience.;)
I would suggest that the greater difficulties with the chromium in stainless steels have little to do with its carbide formation and the nature of the carbides and more with the inherent "stickiness" of the chromium itself.
Anyone who has machined stainless steel even in low carbon grades knows it is very hard to cut cleanly, it forms burrs, and pushes ripples ahead of the cutter, and grabs the cutter. This is why they make free machining grades with the addition of other materials to make it cut cleaner.
I suspect that this is what makes the stainless versions of some cutler steels harder to get a fine clean apex on.
