If you haven't already taken everything apart, you might want to try applying some heat, e.g., with a hair dryer, if you can do so without hurting the knife. The "hardening" of epoxy resins is a self-sustaining chemical reaction; and in general, chemical reactions are not "off-on" processes. Instead, one would expect a rate of reaction somewhere on the scale of very slow up to very fast. In organic chemistry (epoxies are organic), there is a general rule that increasing the temperature of the components by 10 centigrade degrees (18 farenheit degrees) will double (more or less) the reaction rate. If you can raise the tempreature sufficiently to get the reaction to kick-off at a relatively fast pace, it will probably take care of itself from there and proceed on to completion. Good luck.
