- Jun 10, 2019
I honestly can't find any info about whether the blade is on bearings or washers, the most I've found is that it's speedsafe assisted.
If it's speedsafe, I suspect it is just washers on pivot. No need for bearings if its spring loaded. Most all Kershaws I have seen that are assisted openers just use washers. The only non-assisted flippers to my knowledge are the Fraxion, Atmos, Concierge, Method and Natrix , maybe others?- they all use bearings. I wish Kershaw would make more non-assisted flippers with bearings.
Rich
Rich
Thank you for the information.If it's speedsafe, I suspect it is just washers on pivot. No need for bearings if its spring loaded. Most all Kershaws I have seen that are assisted openers just use washers. The only non-assisted flippers to my knowledge are the Fraxion, Atmos, Concierge, Method and Natrix , maybe others?- they all use bearings. I wish Kershaw would make more non-assisted flippers with bearings.
Rich
