Dozier Workhorse -- info request
I do not have personal experience with the Workhorse, but I do with the Buckhunter. Both utilize the tab-lock system. There is a great article on the Workhorse somewhere on this forum with photos. It may be on General Discussion.
As I said I have the Buckhunter which is slightly smaller than the Worhorse. The tab-lock system is a titanium liner that is perfectly fitted into a slot that has been milled out on the inside of the handle. The liner pops over when the blade is open, just like a regular liner lock would. The tab-lock has eliminated the need for the stop pin that the back of the blade normally would stop against. Instead the tab-lock liner supports the blade all along the back of it. This makes for a very rigid blade as there is NO BLADE PLAY WHATSOEVER! I havenoticed that the top tab, the one that acts as the blade stop, has its tab slightly bent inward, guess this gives a more secure stop. Slick as butter to open. Dual bronze washers help out here. The unlocking is via one hand and no more difficult or different from a normal linerlock.
I am really impressed with the Buckhunter, especially since it has a pocket clip. I had a BH a few months ago but sold it because of a lack of the clip. The D-2 blade on this knife is the sharpest blade I own. As stated somewhere else, "there is sharp, razor sharp, and then there is Dozier sharp!" My Buckhunter is the latter.
Art Sigmon
"I can do all things through Christ who strengthens me"
Php. 4:13
"For the word of God is living and powerful, and sharper than any two-edged sword"
Heb. 4:12
Pictures added:
While Bob Dozier is famous for his D2 utility fixed blades, it is a lesser known fact that he also makes outstanding titanium handled folders with – of course – D2 blades. I became aware of this when his "Workhorse" folder was on the cover of “Blade” magazine in February 1999. The article in this issue was about the quality of folders and several people - including Bob - made comments on what they thought would be essential for a good handmade folder. One interesting point caught my attention: Bob uses what he calls the “Dozier-Lock” on his folders. This eliminates the stop pin by relying on a giant locking bar (similar to a double liner lock) which - when engaged - supports the end of the blade over its entire width. Since I liked the design of this particular folder from the moment I saw it on the cover and since I found this type of lock interesting, I couldn’t resist the temptation and ordered the knife in April 1999. Well, time went by and I almost thought I was forgotten until I got a call last week from one of Bob’s employees saying the knife is ready for shipping.
While I knew the size of this folder from the article, I wasn’t quite prepared for the monster when I took it out of the included Cordura sheath. This knife is the even bigger than the Buck Strider! Absolutely amazing when you keep in mind that Bob’s fixed blades are usually relatively small. The overall size is 9 6/16”, the handle 5 3/16” and the blade 4 3/16” long. The blade is 1 5/8” wide and with almost 7/32” even thicker than the one of the Strider! The weight is 8 oz., the Buck knife a “mere” 7.5 oz.
Here the right side of the “Workhorse”
View
And from the left in comparison to the Strider and a (large) Sebenza
View
The overall form of the “Workhorse” is very functional. The handle of course fits even XXL sized hands (like mine) and the small guard and the ridges prevent the fingers from sliding up to the blade. And this blade is amazing! As mentioned, the spine is 7 /32” but it turns into a very thin and razor sharp edge thanks to the very high and shallow hollow grind. This blade is made for cutting and for cutting only. Bob’s grinding abilities are excellent and it shows. There is not the slightest flaw in grind lines or finish. The blade can be opened by using the thumb stud or by pushing on the lower guard which protrudes from the back of the handle when closed. A nice feature when wearing gloves.
Workhorse closed
View
The handle seems to be CNC machined. Besides the grooves on the outside which provide a better grip, the handle slabs are milled out on the inside to make the knife lighter and give it the desired balance. The center of gravity for this knife is there were the cutout in the handle for the thumb stud is.
The right handle slab is milled out on the inside in a T-pattern and houses the giant titanium locking bar. This bar is 2/32” thick (same as on the Strider. It looks different in the picture, but I measured it.) and – as mentioned - supports the entire back of the blade. The head of the T-bar is with 1 5/8” a little bit wider than the handle and its stem is approx. 5/4” wide and 3” long. It fits exactly into the milled handle slot and is secured on the bottom with the screw you can see at the end of the middle groove in the first picture. At first I had concerns if a monster folder of this size can be safe enough without the stopping pin. After handling it for a while I can confidently state that it is! When you open the blade the locking bar snaps in with such authority that you can year it across the room. To test the lock, I pushed the blade through several pages of a catalogue by holding the end of the handle with my left hand and pressing on the back of the handle (not the spine of the blade!) with my left. This way I could penetrate several pages easily but the lock didn’t move or even made a sound to indicate that it would set itself. Needless to say I got the same safe impression when I whacked the blade on the spine. The result is not too surprising if you keep in mind how wide the locking bar is and that it gets its support not from being screwed onto but nestled into the handle slot.
Here the picture from the top
View
and the bottom
View
Overall this knife is quite a monster due to it’s size. No clip is provided but a belt pouch, since you’d never be tempted to clip this knife in the usual manner to your pocket. Sharpness and slicing ability are excellent and the clip point shape of the blade make this folder quite useful. There is no way to use this blade in any kind of prying without breaking of the fine tip.
If you’ll ever come in a self defense situation and you have this folder with you, there will most likely never be the reason to actually use it. Everybody who’ll see you open this knife will be intimidated just by the look of it
The craftsmanship on this knife is flawless and I can highly recommend it to anybody who’s looking into a big folder with a unique lock and an excellent blade steel.
[This message has been edited by Ralf (edited 05-14-2001).]
Ralf, thanks for adding the pictures. The small hole in the blade looks to be without a function, or I missed something. The lack of a stop pin is something I have to think through--I see how the design works, but subjectively it feels less secure.
It would be very interesting to compare the Strider Custom drop point, it's considerably beefier than the Buck version.
Overall, I think I like the blade better than the handle, but that's based on nothing more than looking at pictures. In the meantime, I have a Mayo Beefy-T in the pipeline, but the Dozier is definitely something that I'm keeping on my list.
Of course if anyone out there is tired of their Workhorse, let me know...
Steve
Yeah, thats the article I was talking about. Thanks Ralf for posting it. Steve, if you get a chance to handle one of the tab-lock folders I think you will be impressed with how sturdy it is. I was skeptical at first about the loss of the stop pin but after handling, spine-whacking, and spine-whacking again I decided that I liked the sturdiness of the design. If you really want sturdy check out the new Trapper models. These have the locks cut into the liners and are 2 to 3 times thicker than the WH or BH liners.
Art Sigmon
Php. 4:13
Heb. 4:12
Steve (sas),
The hole in the blade is for the ball bearing in the lock leaf to rest in when the knife is closed. Part of the ball bearing detent system like on a liner lock.
Paul
