I do plenty of draw filing on larger knives. The blade is clamped down in front of me with the tip pointing toward me, and I pull (draw) the file toward myself from the ricasso shoulders to the tip.
The file is directional. For the pull cuts such as I do the tang of the file goes in the left hand. For a push cut tip to ricasso the tang of the file would go in your right hand.
When you start out the going is slow and you may think that it's not going to work. But just keep going with nice even strokes. Once the uneven flats start to work down you will progress quickly.
Things To Remember
- Don't be tempted to scrub back and forth. You will ruin the file and it won't help your work at all.
- Keep the teeth of the file clean. Little chips of the steel can get embedded in the teeth and will gall the piece. Galling means that it will score a deep scratch in your nice smooth piece. You can use a file card or a small stiff wire brush to clean out the teeth. I usually just whack the file on the workbench every couple of strokes. Of course I also check to see that it's clean before making another stroke.
- Don't work just one area. If you have a scratch in a low spot you can't just work that area to get the scratch out. All you'll do is create a divot. The entire surface from ricasso shoulders to tip has to be brought down. When you are dealing with a low spot, an easy way to check your progress is to paint over the low spot with a Magic Marker. As the rest of the blade is brought down you will begin to "erase" the area that you've colored in.
- Be patient. Draw filing is not as bad as some folks think, but it's certainly not like using a grinder with a 60 grit belt. It takes time and patience. The results are rewarding when you've done the job properly.
This Bowie was primarily done by draw filing. After forging and annealing I did use the grinder to knock off the "bark" from the blade bevels and define the ricasso shoulders a little better.
Then I went from a 60 grit belt to draw filing with a standard bastard file. Once everything was flat I went to a finer mill bastard. The final finish was done after heat treating by hand rubbing, starting with 120 grit paper wrapped around a file, progressing through the grits to 1000 grit.
My sanding and draw filing fixture
The blade must have support. Because of the distal taper of the blade, the tip will be suspended in air. So will part of the center of the blade. So you have the problem of the middle of the blade bowing and the tip bending as you draw the file across the blade. The bow will cause you to dish out the center, and the tip will bend causing you to round it off.
Here's how I address that problem.
I use the same fixture for my draw filing that I use for hand sanding. This helps resolve these problems of the center bowing, and the tip bending. I don't have a good shot of the fixture, so this will have to suffice for now.
I have a strip of leather with a hole in one end. The clamp bolt pictured above goes through that hole. The strip of leather is to protect the blade. The reason of the oblong milled hole in the clamp is so I can move the clamp left or right as needed.
The tang goes under the clamp and is secured. Then the pieces of all thread are brought up to support the blade all the way to the tip. So you don't have the bowing and bending, and you won't hear that *thunk* or *boing* as you come straight off the tip. Works like a charm. I can do anything from a 2 1/2" blade to a 12" blade with no problem.
