G'day all,
I ran a thread a while back asking for feedback on some filework I'd done, and got some great responses.
(http://www.bladeforums.com/forums/showthread.php?t=695282)
I also had it recommended to me that I get myself a foredom tool or something similar if I wanted to go further with that kind of work. Thanx to my wonderful fiancee I now own a Dremel, and I've been experimenting with it in my fileworking for a couple months now. Problem is I'm not getting the results I was expecting, in fact so far I've found I get the work done quicker and with more precision using hand files
I was wondering if there was anyone else out there who has done some filework using a foredom tool or dremel, and has any hints or suggestions about using it. My biggest problem is if I haven't gone deep enough on the first try, then it's hard as buggery to grind in the exact same spot again in order to grind deeper without getting overlapping grind marks (hard to explain, but if you've tried it hopefully you know what I mean).
eg:
(something like this... sorta
It's a pain because I've found my grinds are much crisper with the dremel when I get it right, but it's so unpredictable especially when it comes to depth that I invariably do my pattern experiments with my handfiles. Is this normal? Do most people use handfiles for their filework, or do they predominantly use dremels and foredom tools but have some sort of knack that I don't? Any help or info would be welcome
eg:
