Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Just how big of a drill press do you need to use a 1in drill bit? Could using a larger drill bit(with a smaller shank) damage a drill press? I have a larger Delta drill press and used a 3/4in drill bit the other day and the hole it drilled seemed a little off. The part drilled was locked in a xy vise. I slowed speed down to 200rpm and flooded with cutting oil while drilling of course.
Chasing a hole with another larger drill can be sketchy.
When drilling a large hole on an industrial machine I'll drill a pilot hole the size of the web of the drill, then follow that with the big drill. I understand that sometimes a smaller machine might not have enough grunt to go directly to 1" so I understand the need to use intermediate sizes, but without the web engaged the drill is going to wander around so you probably won't get a round hole and there is a dangerous tendency for things to bind up. If you go that route you need to find the right amount of feed and back the hole with something. If only the corners of the drill are engaged in the cut it will tend to over feed. A 1" hole would be done at ~200 RPM. This is about as big as I'll drill on a full size mill.
I'm only mentioning this if someone wants to drill, but a hole saw is a better choice. You can drill the pilot hole for the saw separately and install a solid pin in the saw for better results in difficult materials
I've drilled countless 1" holes with this carbide-tipped holesaw from McMaster-Carr chucked in a cheap HF drill press. I think it was around $60-70, but if you're drilling lots of 1" holes, especially in high vanadium steels, it's worth its weight in gold! If you only need to make a couple-few holes, the much less expensive bi-metal holesaws may suffice.
