- Jul 13, 2009
Can anyone recommend a reasonable - efficient - cheap ways to create a few holes?
2 1/4" or 2 1/2" holes in 1/4" to 1/2" steel ?
Round would be nice, but not required.
Methods under consideration.
Step drill - I haven't found one that big & am afraid of the $ if I do.
This would be my favourite option - clean and chatter free cutting.
Twist drill - to thin for that without the "helicopter of death".
Indexable tooling carbide insert spade drill - $$$
Bimetal hole saw - seems like the best option so far but will they cut steel ?
I've had bad experiences with some that wouldn't cut metals.
Diamond grit hole saw - seems like a good option but will they cut steel ?
seems like they are made for brick and masonary.
Torching the hole as best I can and filing it out.
labour intensive- but maybe
Drilling a circle of small holes and filing it out.
labour intensive. - but maybe
Milling machine with rotary table - maybe in a year or two, but not today.
Lathe faceplate and boring out - workpiece is too big for the swing of my lathe
Waterjet or torch cut by outside service - prohibitive setup costs for a one off project
Boring head in a drill press - - possible but I might need 2 heads to go from a small hole to finished size because of a limited adjustment range for each.
I'm considering trepanning & making this sort of thing but bigger and with lathe HSS bits - but I don't want to work that hard for a few holes.
http://www.holesaws.com.cn/products/holesaws/adjustable/pic/11001002.jpg
What am I missing ?
Simple and cheap are more important than production speed.
What am I missing ?
